In NAMBA, you can parallel all you want, but total capacity can't exceed 10,000 for P. So, if you run twins, it's 4S1P 5000 per motor.
There ARE other configurations you COULD do, but the total capacity can't exceed 10,000 (N2 thru Q. S-T allow 12,000). Only P-T allow multiple motors.
c. There are two acceptable multi-motor configurations for the Power
Specifications that allow multiple motors:
I don't know of any records that have been set with anything other than 2 motors, each powered by the applicable voltage and the mAh split between them, but I don't look inside of ALL the bigger boats.
i) Each motor must see a nominal voltage within the Power
Specification. The mAh capacity maximum within the same Power
Specification is for all motors combined.
ii) The sum of the nominal voltages powering each motor must be within
the Power Specification. The mAh capacity maximum within the
same Power Specification is for each motor.
