Silver Solder or Good Old 60/40 Rosin Core
  • Monger
    • Jun 2014
    • 17
    I've been soldering on connectors for my new SF 220 Amp ESC. I noticed the 8/10 Ga silicone wire that i've been receiving is silver stranded (no more Copper I Guess) Currently it's hard to find old leaded solder. What's better to use on wiring, and connectors?
    Monger
  • NativePaul
    Greased Weasel
    • 2761
    I like 63/37 myself but 60/40 works well too, the temperatures needed to silver solder will anneal your connectors lowering their spring pressure and increasing there resistance, the heat also risks damaging any electronics on the other end of the wire, blowlamps can also introduce static charges that pose a risk to electronics, so I would highly recommend using something that can be melted with an iron or gun.
    • jcald2000
      • May 2008
      • 774
      The silver is "tinning" it prevents Black Death. I use 60/40 on 8mm bullets with no problems at 200 amps.
      • Namba328
        Factory Team Pilot SPP
        • Jul 2011
        • 1117
        I use 60/40 on everything I run. 5.5, 6.5 and that's even on my battery leads. I've never had any problems.
        Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
        Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
        • Luck as a Constant
          Make Total Destroy
          • Mar 2014
          • 1952
          60/40 is fine
          • rearwheelin
            • 1941
            I use 60/40 as well . Never any issues. Use a propane torch to heat the bullet then just start feeding the solder into it.
            --Albert Einstein
