Nemesis = Feigao?
  • motoxbob11
    • May 2007
    • 190
    Nemesis = Feigao?
    I own a "Nemesis Blue XLT-4" motor that needs to be replaced. It is supposed to be a 2 hp @40,000 rpm motor that looks just like the Feigao that Steven sells. I would like to replace it with one from OSE but I don't know which wind would be about the same speed. Is anyone familiar with the Nemesis motor and if so which Feigao would be the closest to the XLT-4? Thanks in advance.
  • Eyekandyboats
    • 1921
    well XL-t4 is XL can turn=4 .... or a 4 turn also known as a 4XL.... which is basicly unheard of unless you get a hacker.... i dont think fieago makes a motor like that
    what was the motor out of.. how many cells and what prop and what hull?
    EYEKANDYGRAPHICS
    www.rclipos.com
    • motoxbob11
      • May 2007
      • 190
      The motor came as part of a Fine Design electric conversion kit for a gas truck. The motor has "XLT-4" etched on it (By hand). I can't find this motor on his website or anywhere else. I want to get a Feigao from Steven to replace it but I need to know how hot of a motor it is because the gearing can't be changed to accomodate different motors so I need a motor that is pretty close to this wind. I use it in a truck but I was hoping someone has knowledge of how these motors compare.
      • Eyekandyboats
        • 1921
        ..... what is the cell count and esc being used ?
        EYEKANDYGRAPHICS
        www.rclipos.com
        • ghostofpf1
          • Jun 2008
          • 392
          I have read that the XLT-1 motor was equivalent to a 7XL Feigao if that helps.I purchased a XLT-4 motor from him years ago for my LST conversion but never found out exactly what wind it was ?? Maybe a 11XL....
          Good Luck
          Ghost
          • motoxbob11
            • May 2007
            • 190
            I am using a Castle Hydra 120 on 4s lipo.
            • motoxbob11
              • May 2007
              • 190
              Good Luck
              Ghost
              That is exactly my problem what the heck is it. It ran just fine but finally expired.
              • Doozie870
                • 828
                Chris Fine = Pinocchio, I call him pinoc for short
                • Eyekandyboats
                  • 1921
                  losi LST with a marine esc? how does the brake work? normal brake rotors and pad on the drive shaft?
                  any how. sounds like it would be a hi wind motor. not sure on the gear ratio but i know my buddies traxxas conversion ran a 7XL on 4s through the trans.
                  find out the stock RPM of the nitro motor and then we can help you out even more
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • motoxbob11
                    • May 2007
                    • 190
                    It is pretty neat how the brake works it uses the original mechanical linkage so when you push the trigger forward to "reverse" the throttle servo actuates the brakes. The speed control has no brake function of course. I don't know the original rpm of the nitro motor but it probably is an apple and oranges comparision anyway. I think the Nemesis motor is a fairly high wind motor and thats what I am trying to determine.
                    • motoxbob11
                      • May 2007
                      • 190
                      To avoid confusion I forgot to add that the reciever is wired to control both the speed control and the original throttle servo at the same time in order to provide braking.
