Motor timing for 1600 kv Leo 4082/ Sea King 180
  • champion221elite
    • Jul 2013
    • 216
    I'm running a Leopard 4082, 1600 kv 4 pole motor with a Sea King 180a esc in my Sprint Cat and have programmed the esc for 6s.
    After scouring the web, Ive seen anything from low timing up to around 15 degrees.
    I have the program box, so changing the timing is no problem. Where should I set the timing for extended motor life and reduced heat? I'm currently turning a modified X448 and it pushes the Sprint Cat to 65-68 mph no problem.
    I'm open to any suggestions you may have.
  • martin
    • 2887
    That is a y wind motor so needs medium timing, on the SK 180 set @ either 11.25 degrees or up to 15 degrees.
    • champion221elite
      • Jul 2013
      • 216
      Thanks! I'll drop it down to 11.25 degrees.
