Ok I might have to then I wouldn't have thought that prop would be to big for a 4074 motor at 1650kv
First run with new motor/esc
Hello,
Is your boat running wet ?
And is the flex shaft running nice and free ?Comment
Ok,
What cells are you using and what connectors ?
Have any pictures of the boat and the setup that you can post ?
Also what was the temperature of the water where you were running at ?
Do you live in Brazil ? Br stands for.
What kind of 6s cells do you have, C , Mah , Brand.
I would try shorting the wires on the motor to esc,
There are to many connectors and to much wire to.
Also go with the 5.5 on the cells to and get rid of the series wire.
I think that may help a lot for the whole setup all around.
Also in the pictures where the straps are,
I would move the cells back toward the transom to the next set of velcro pads.
Than if it air out to much lower the trim tabs some,
Or the strut setting to level and tabs up 3.5mm from bottom of hull.Last edited by lenny; 05-05-2013, 02:07 AM.Comment
They 5000 mah 45c turnigy nano tech. Can't shorten the wires that was the only place to put the motor and esc so i had to lengthen them as it was which i didnt want to do. I didnt know to go with bullets on the cells till a member said last week and I had already soldered everything on
What's life if you ain't having funComment
Take a picture of the rear of the transom and hardware at prop eye level please.Comment
You just need to move the esc 1 or 2 inches and it will work a lot better,
Just use a velcro strap to hold it in place,
Than when you need to grease the flex shaft and get to the coupler it can be moved easily to the side.Comment
From looking at all the pictures now,
I think the whole setup is fighting it self to run on plane.
Hardware was that is and cell placement to,
And you should fix the wires and connector to.
I would set the strut level and the tabs to,
Than move the cell back to the next set of pads.
And test how it runs like that,
Than change one thing at a time if you have to.
I would need to see how it running first, Than make the change.Comment
Ok good luck with it.
? ONLY IF THEY WORK
