5.5 On 8s and 10s with a Hv 240a & 5692 730kv in a 48" mono.
  • lenny
    • Sep 2010
    • 4294
    Hi,
    Will 5.5 bullet be ok on this setup for a 48"mono,
    Using 8s and 10s some times.
    Setup will be a Swordfish 240a HV and a 5692 730kv,
    With a x447/3 to start with or a x452/3 or x455.
    Let me know what you think.
    ? ONLY IF THEY WORK
  • keithbradley
    • 3663
    Depending on what hull it is, I would probaly START with the x455 and go up from there...unless it's some sort of scale hull that can't handle it. A x447 is tiny for a hull that size, adn you won't be spinning it very fast.
    That said, you will be pulling less current than a lot of guys do with 5.5mm bullets. I find that quality of solder is usually the suspect when people have hot bullets. I run 5.5mm bullets on some pretty aggressive setups and have no problems. I wouldn't be the slightest bit concerned with this setup.
    www.keithbradleyboats.com
    • lenny
      • Sep 2010
      • 4294
      Ok thanks for the info,
      The boat is this one, The 48"Stealth that Peter had.
      It is a thick heavy hull,
      I was not very sure on the 5.5 bullets and what amps they will handle.
      And yes, Good soldering is a key for good connections and low resistance.
      http://forums.offshoreelectrics.com/...h-2230-Powered
      http://forums.offshoreelectrics.com/...uot-boat<br />
      ? ONLY IF THEY WORK
