Balaenoptera Musculus. Upgrades?
  • masonis1
    If you cant control it 👍👍
    • 1173
    #106
    There you go. Have you done other work?
    • seehuusen
      • Apr 2012
      • 96
      #107
      Hi Mason,
      I haven't done anymore work on the boat, I'm waiting until friday to get paid :p
      Then I'll put an order in for rudder, stringer, dremel (needed for the inside and other work), motor mount, servo, and possibly the motor too, dependent on availability of the right Kv and size motor...
      Cheers
      Martin
      • masonis1
        • 1173
        #108
        Ok sounds good
        • seehuusen
          • Apr 2012
          • 96
          #109
          OK, the list is nearly complete... Boat is intended for 3S
          Motor:
          XK3665-B-2500KV Brushless Inrunner
          36 Size Adjustable Motor Mount with Water Cooling
          Water Cooling Jacket for 36mm Brushless Motor
          ESC:
          Not sure, will update
          Running Gear:
          all 4mm gear
          Flex cable with end (approx 300mm long)
          Outer tube (Use with teflon liner, 300mm long, 6mm x 0.2mm thick)
          Drive dog
          Threaded prop nut
          Teflon thrust washer (to use between drive dog and strut end)
          Teflon liner (Suits 4mm cables, 300mm long, 4.5mm id x 5.5mm od)
          This is paired up to a 70mm long 4mm adjustable Stinger
          Rudder:
          130mm X 32mm wide Rudder dual pickup version (130mm deep X 75mm offset rudder with dual pickups, Uses kick back funtion for safety, mounting bolts included)
          Servo arm, piano wire or what ever
          Servo arm boot
          Metal Gear Digital Servo - MG995 - 15kg thrust
          Props:
          ???? 33mm - 36mm at what pitch? 1.4? I want to buy a small selection of props, preferably plastic, that I can then test out, and buy the better cnc prop after that...
          What do you guys reckon?
          Cheers
          Martin
          • masonis1
            • 1173
            #110
            This boat really doesn't need more than a 60a esc
            • masonis1
              • 1173
              #111
              My pitch is also 1.38 I think so 1.4 would be good
              • seehuusen
                • Apr 2012
                • 96
                #112
                sweet!! :) Thanks Mason, I'm about to order all of it on my lunch break :)
                • masonis1
                  • 1173
                  #113
                  When's your lunch break. It's 615 where I live
                  • seehuusen
                    • Apr 2012
                    • 96
                    #114
                    LOL, I'm in Australia mate, it's 2.30pm now here :)
                    I just posted updates to my thread on the other forum, I can post in both places if people want?
                    Speed - Electric - Brushless Balaenoptera Musculus - Hey fellow modders :-)I have gone and purchased another toy boat to modI really like building these boats; it gives me no end of pleasure.It’s relaxing to
                    ALL the gear needed has been bought, ended up costing me about AU$300 all up, which was a little more than I planned to spend... I've got a theoretical speed of 86 km/h at the moment, so I should be able to meet the 50+km/h as I intended :D
                    Cheers
                    Martin
                    • masonis1
                      • 1173
                      #115
                      I'd like to see it here too plz
                      • seehuusen
                        • Apr 2012
                        • 96
                        #116
                        a bit of progress today
                        I went to the local hard ware store and got a dremmel copy, very happy
                        So I got rid of all the little bits inside the boat, and cleaned it up
                        Then I made a new transom from some 3mm ply, which I fibre glassed into the boat to make it a bit stiffer and to have somewhere stronger to mount the gear
                        Pictures attached, it's all curing right now
                        Cheers
                        Martin
                        IMAG0742 (Medium).jpgIMAG0744 (Medium).jpgIMAG0747 (Medium).jpgIMAG0748 (Medium).jpgIMAG0749 (Medium).jpg
                        • seehuusen
                          • Apr 2012
                          • 96
                          #117
                          filled up the holes on the out side, hoping it will make it a bit more streamlined :)
                          • masonis1
                            • 1173
                            #118
                            Looks good. Nice work
                            • seehuusen
                              • Apr 2012
                              • 96
                              #119
                              a bit of an update...
                              Transom is finished, rear holes blocked and sanded.
                              The cast holes are filled out
                              I've made a piece of ply fit as a floor, to stiffen the boat on the length. It will be glued in place
                              I also painted the bottom outside of the hull, and it came up sweet :D
                              Cheers
                              Martin
                              IMAG0755 (Medium).jpgIMAG0756 (Medium).jpgIMAG0757 (Medium).jpgIMAG0758 (Medium).jpg
                              • seehuusen
                                • Apr 2012
                                • 96
                                #120
                                hey guys
                                I made a servo and Rx box on one side of the hull.
                                I don't really like the balloon setup, I can't seem to get the servo to sit 100% still when it has a balloon wrapped around it, so I made this, it'll be water proof... as much as a baloon or glued up glove anyways
                                ...and how is this for close on the weight, ESC weighs in at 105g and the servo, Rx and the wooden box is 103g I'll do a final calibration once in the water, but that's very close
                                IMAG0762 (Medium).jpgIMAG0764 (Medium).jpgIMAG0768 (Medium).jpgIMAG0772 (Medium).jpgIMAG0776 (Medium).jpg
                                a few pics of the progress so far... I think I'll be waiting on hardware, it should all arrive this week, hopefully
                                Cheers
                                Martin
