Sea King 180 up in smoke
I don't know if there is an "official" way to test if a motor is shorted, I just know that's how it happened to me on a new AQ 1800 kv motor with 2 runs on it. It fried the ESC, which then overvolted the receiver and took that out too (with a tremendous flash I might add).Comment
I don't know if there is an "official" way to test if a motor is shorted, I just know that's how it happened to me on a new AQ 1800 kv motor with 2 runs on it. It fried the ESC, which then overvolted the receiver and took that out too (with a tremendous flash I might add).There is no replacement for displacement, I guess I just have to Buzz it higher!Comment
You can buy some Multimeters with an Inductor Testing feature, then you check between each phase, I had an Ammo 2300KV let go, and when I checked it, you can see that one phase had shorted by the difference in readings from the other phases. Take a reading of your new motor first, write them down and keep them somewhere, then if later you think your motor is bad, compare the readings.
Thanks,
Tony2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
