where can i get one of those strechy rx waterproof things?
Rx waterproof.. bag?
Tags: None
Just get some large size toy balloons at the local Dollar store and cut the necks off. Seal it with a nylon zip tie.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
Find a small zip lock bag. After inserting the receiver, twist the open end very tightly around the wires and use two small zip ties. Works great for me. Much easier than a balloon.Mini Cat Racing USA
Much superior to ballons as you can see any moisture in the bag. I prefer the freezer bags as they appear to be a little thicker. BGComment
Go to hobby lobby and get some smaller jewelry bags...they work well.Comment
hard to find any freezer bags that are small enough. Do you have a source?Mini Cat Racing USA
I just use the cut off finger sections from latex gloves. Get the extra large size and all but the pinky finger are just the perfect size. Then seal the end with a zip tie around the wires. Never had a drop enter my Rx since using this method.
I used the figure of a plastic glove, see how that goes. Ill probably switch to a plastic bag soon b/c its a little bigger. Thanks guysComment
latex gloves, larger ones can fit your ESC too if you cut a finger for the wires on the other side, pretty much a flexible radio box.
Non lubed condoms, balloons, or really anything latex or rubber and stretchy. You don't have to cut the neck off, I have squeezed very large receivers through, although you may need two people to do it.Comment
Non lubed condoms, balloons, or really anything latex or rubber and stretchy. You don't have to cut the neck off, I have squeezed very large receivers through, although you may need two people to do it.Attached FilesI let the dogs out...Comment
