Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Pursuit flex drive - Offshore Electrics Forums
Pursuit flex drive
  • club17
    • Jan 2011
    • 16
    Pursuit flex drive
    I have a pursuit with a two piece shaft. I would like to replace it with a flex shaft. What would you recommend. What else would have to be changed to fit a flex shaft. Where would i get the parts required. Is this easy to do. Instructoins on installing the shaft would be appreciated.
  • Jabbo
    • Jul 2009
    • 443
    Kintec racing. Pursuit upgrades.
    • JackBlack26
      • May 2007
      • 905
      It should be the same as it was on my Genesis. Drill out or pull out the 4mm bushing in the strut and replace it with 3/16 bushings. Install 3/16 prop shaft and new cable. I used .150 size cable on mine but could of gone with .187 cable. Really easy to do.
      • keysguy
        • 10
        Club17,
        You are asking some of the same questions I have. I just ordered a Pursuit from Kintec. I'm used to dealing with the RC heli world and when I bought any new heli I ordered tons of spare parts. For some stupid reason this time I did not think about spare parts or upgrades even though I read all about them. Not to hijack your post but suggestions on what "spare" parts I should keep on hand would be greatly appreciated. So far on my list of stuff to order before I make a run is:
        Shaft grease
        one piece shaft
        strut seals
        Thanks,
        Keysguy
        • JackBlack26
          • May 2007
          • 905
          Heli's are nothing like boats. I fake my boats out and don't break anything. There really is nothing to break unless you break the boat it's self it burn up the electronics. I just got in to Heli's. I have tried to fly 4 times and every time has oat me a trip to the LHS. Not the case with boats.
          So with that said, grease, hatch tape, and props is pretty much all you will need.other than batteries of course.
          • JackBlack26
            • May 2007
            • 905
            • 6sHyper
              <<<Surfs up!
              • Jan 2011
              • 597
              I believe these parts will do the job:
              http://www.offshoreelectrics.com/pro...oct-oc150L-24c
              http://www.offshoreelectrics.com/pro...=ros-spdsd-187
              you should be able to just drill the 4mm out to the size of the new 3/16 bushing.
              • club17
                • Jan 2011
                • 16
                Do I have to replace the liner and stuffing tube with this upgrade.
                I thank everyone for all your help.
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  Club 17.
                  There's a bit of a description in post #11 in this thread on how I replaced the bearings in a second hand Pursuit that I built up. It was a strut but I've done the same thing with stingers if that's what you have on yours.
                  As I went to a .187 flex I also replaced the stuffing tube & liner because the .187 flex was too tight in the 4mm liner.
                  Cheers.
                  Paul.
                  • 6sHyper
                    <<<Surfs up!
                    • Jan 2011
                    • 597
                    With the parts i listed no. The .150 flex will fit in your stock liner for the 4m flex real nice.
                    • speed restricted
                      Brisbane boat floater
                      • 12
                      thanks for the link Paul. a few good tips in there for setting up my FFRpursuit when my motor and servo mount arrives
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        You are most welcome.
                        But don't bother raising the drive line exit in the transom like I did. I had to drop it back down again as it was running too wet.
                        Hope to see yours on the water soon.
                        Paul.
