I use Dupli-Color Perfect Match Automotive paints. VERY light coats for the first 4-5. More like fogging the hull until the color becomes solid. If you lay it on too thick, it won't stick and will "fisheye". The light fogging allows the paint to completely bond to the hull. About 10-20 minutes between coats, again VERY light until the hull becomes a solid color. Sometimes I've hit 10 fogging coats and usually use an entire can of paint.
Then I use about 4-6 coats of Clear Acrylic. Either Lacquer or Enamel, but don't mix. The final coat is thick, almost running. Then it bakes.
I use halogen heat lamps with an IR sensor to "bake" the hulls at about 120-140 for 8-12 hours. Have to watch the vinyl to make sure it doesn't curl.
Before painting, I scuff the hull with 150 grit sand paper to give it some good deep scratches so the paint can bond. The spray paint is thick enough to fill them, don't worry.
Optionally, I sand in between clear coats with 1500 grit wet paper.
This formula has held up quite well, starting with last year's Das Boot project which still doesn't have a single chip in it. (Except where the rudder broke) I paint all of my hulls this way now. Have to make sure to break the "glaze" on every bit of area being painted. If you miss a spot and it's shiny, the paint may chip loose.
Hope this helps!
Hope this helps!
