Tube slidding
  • Lilrich
    • Feb 2011
    • 94
    Tube slidding
    HI Guys Just got a used MG. Said not used much. Trouble is,the teflon/plastic liner keeps sliding up to jam nut. Why. What do I do to fix. Will getting new liner fix. Any help will be appreciated.
  • egneg
    • 4670
    Use a bit of water tubing to keep it in place. Overlap the stuffing tube and teflon liner.
    IMPBA 20481S D-12
    • SweetAccord
      Speed Passion
      • Oct 2007
      • 1302
      You can also add a new longer tube if you have one.
      • Lilrich
        • Feb 2011
        • 94
        Ok But is the tubing or longer tube going to hurt riding on the flex shaft or nut.
        • ron1950
          • 3024
          mine slides up to the jam nut ......dont worry about it just keep flex shaft greesed well.....
          • Lilrich
            • Feb 2011
            • 94
            YA I greased shaft, push the liner back,put back together and hit throttle one time POO- GREASE EVERWERE.Lots off cleaning. THANKS for the input everyone
            • sundog
              Platinum Card Member
              • Feb 2009
              • 878
              I use a piece of shrink tubing - it helps with both problems.
              Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
              • Lilrich
                • Feb 2011
                • 94
                THANK YOU GUY'S Really appreciate the advice.Rich
