HK Vanquish
  • Diesel6401
    Memento Vivere
    • 4204
    #106
    Originally posted by FighterCat57
    like it's a copy of a copy.
    *that would explain a lot... Use a lot of FG or CF Ben, she's real weak on the bottom and the gelcoat cracks really easy.
    - Diesel's Youtube
    - Diesel's Fleet
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      #107
      Since I have both here, I'll get some side by side photos. I'll also ask TFL if they make this hull. The hardware is clearly of less quality than the other TFL items I've seen.
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3480
        #108
        OK, I can CONFIRM, the Vanquish is NOT a TFL hobby product. It is a cheap knock off of the Osprey which is a knock off of the DF 41.
        The parts quality, fiberglass work and assembly are nowhere the quality of the Osprey, which is of good quality.
        Wow. It's clearly an exact clone. Not even 10%, an exact fiberglass clone.
        TFL uses a numbering system inside their hulls. The Vanquish does not have these markings. TFL also has nice finished aluminum hardware, where the Vanquish has rough castings of similar parts. Everything about the Vanquish & hardware screams cheap clone.
        Doesn't mean it won't work. I'm using mine for a salt water sport setup, so it's perfect for the job. Check out the rough surface on the turn fins and the plating flaking off the new coupler... Yikes!
        The Osprey has properly mounted trim tabs and strut. Still has the stuffing tube gap problem, but at least it isn't mounted too low. Also the stuffing tube on the Vanquish is kinked. Ack!
        • BLAZE WON
          • Sep 2010
          • 43
          #109
          i just got my vanquish today. it was ordered when they first appeared on the hk site. it has the same problems that everyone elses has. how do you think this would run on a neu 1527 2d 1150 kv on 6 cells? thanks in advance for any responses.
          • Diesel6401
            Memento Vivere
            • 4204
            #110
            WOW great info Ben. Pisses me off a little. I should have sprung for the Osprey if it's built anything like the Pursuit it should be a real screamer. Makes me wanna sell this freaking thing lol... I will go with it though.
            - Diesel's Youtube
            - Diesel's Fleet
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              #111
              Don't let it bother you. It's a hell of a deal at the price.
              Just clearly not the level of the TFL products...
              Tick... Tock... 1717 mounts are in the mills this week...
              • Diesel6401
                Memento Vivere
                • 4204
                #112
                RPMS are a little low on 6s. 7 or 8s may work better for ya. Just my 2 cents.
                - Diesel's Youtube
                - Diesel's Fleet
                • 6sHyper
                  <<<Surfs up!
                  • Jan 2011
                  • 597
                  #113
                  How much can you sell one of them mounts for??? sure looked nice them red ones with rails.
                  • 6sHyper
                    <<<Surfs up!
                    • Jan 2011
                    • 597
                    #114
                    Just recieved my Vanquish today, On mine the trim tabs were slightly above the bottom surface of the hull by 1.5-2mm, which is good, the one is touching the rudder mount though, but should be fine. As for the stinger it is FLUSH with the bottom of the hull. I am going to raise it a couple mm's. should be simple. As for the boat it looks great, although the fiberglass is piss thin, it will be getting a couple layers of fiberglass immediately. I dont see it nessasary to reinforce the transom as it has a ply layer and seems to be good and solid. Pretty sure a 1717 would snap right outta this hull if someone were to try and run it without adding extra glass or CF, lol
                    I'm starting with 1717, T180 6s, m447, just purchased an eagle tree 150a from ose so will be able to push this setup to its limits which i have no problem doing as i've had nothing but good luck with the T180's so far.
                    Oh an dalmost forgot, as Diesel said, this thing is huge!!
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      #115
                      Finally finished this POS.. Ran into ANOTHER problem. Heads up don't use the stock coupler. That thing is so freaking untrue it's not funny. I spun the shaft by hand and I could see the coupler wobble and I could see the stuffing tube moving. I swapped couplers and all was good. Maiden tomorrow is weather is good.
                      * Ignore my terrible looking FG job, looks like hell but strong like bull lol...
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • chummer
                        • 636
                        #116
                        Looking forward to your results, Good luck. Are you going with 5S first? Are you mounting the batteries in front of the motor?
                        "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          #117
                          Gonna go with 6s2p using the Blue Lipo's from Hobbypartz. Never used them before but heard they work good. One thing I don't like already with them is the small gauge battery wire.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            #118
                            have you thought about the 6s long lipos? They are 3s & 3s longways, so lay pretty flat and are low and even. I'm thinking about going that route for 6s2p as well.
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              #119
                              Thought about it, been then realized I maybe limited with hulls I can put them in. Ben sent you a PM...
                              Guys I tested this boat today and I can honestly say it's pissed me off to the breaking point. I am washing my hands of this hull. It in the SS currently.
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Daniel2000
                                • Feb 2011
                                • 9
                                #120
                                what'S wrong now Diesel?
                                HK Vanquish, Leopard 4082 1250kv, Turnigy Marine 180A ESC, Turnigy 5000mAh 6s 40c, Octura x447 = 40mph
