I tried one with my Ice 200 and no matter what I do I have to give over 1/4 throttle just to get the motor to move. For you guys that are using the Pistix with the Ice controllers is that normal?
Is anyome still using a Pistix adapter with the CC ICE esc's?
Team Liquid DashTags: None -
Did you calibrate the throttle in the ESC program? Not sure the ICE requires that but most of the ESC's I use, that's the very first step.Mini Cat Racing USA
www.minicatracingusa.com -
Yep I cablibrated and played with the end points and sub trims with no effect.Team Liquid DashComment
Call Castle Tech Support!
(913) 390-6939
*Option 1 - Technical Support
*Option 2 - Repairs
*Option 3 - Sales / Orders
Office Hours: Monday - Friday from 9AM to 5PM CST.Mini Cat Racing USA
Ray,
The PiStix puts out an extremely low "off" in the off position, 1.0ms. Most ESCs like to see 1.1ms. This was done because there are a few that either auto-calibrate (and then it's no problem) or that need the 1.0ms.
I would put a Y adapter into the rx and see what is happening to the signal going to the ESC. It may be that you need to calibrate the Tx to the PiStix first.
AndySpektrum Development TeamComment
I still do and they seem to work normal.If all of your wishes are granted, many of your dreams will be destroyed!Comment
Andy do you mean the way the Pistix instructions describe?
Baked are you using a Spektrum radio??Team Liquid DashComment
