stripping paint off a Vac-U-Pickle
  • sailr
    • Nov 2007
    • 6927
    Oh hell yeah! It is a strong solvent. I've used it a lot for various things. It will eat up your hands. Just eats the outer layer of skin. It won't take your fingers off!! ;-)
    Mini Cat Racing USA
    www.minicatracingusa.com
    • JimClark
      • 5907
      Purple power didn't even do anything to the Fusion paint.
      Onto brake fluid if that doesn't work then I go get some of the ctri strip Darin recommended
      Billy Graham
      • JimClark
        • 5907
        unless it has to stay on doe a while brake fluid doesn't touch it either.
        Jim
        Billy Graham
        • egneg
          • 4670
          It can take 24 hours for brake fluid to work. That is why I said small parts that can be submerged.
          IMPBA 20481S D-12
          • Darin Jordan
            • 8335
            Jim,
            If you are willing to run up to my house... I have a can of Citri-Strip that you can borrow if you want to try before you buy. It's a little spendy, so you might as well find out first. I'll be home all weekend, and all next week.
            Darin E. Jordan - Renton, WA
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5190
              Jim, the old fashioned method...wet sandpaper...the gray stuff. I would not use a chemical on that hull material.
              Douggie
              • sailr
                • Nov 2007
                • 6927
                I didn't think it would. I'd be amazed if brake fluid works either. The fusion paint is pretty tough unlike the el-cheapo $.99 enamel.
                Mini Cat Racing USA
                • JimClark
                  • 5907
                  I am not opposed to the old fashioned wet sanding method wich is probably what I will do
                  Jim
                  Billy Graham
                  • T.C.
                    • Sep 2009
                    • 236
                    I would read the label on a Fusion can and get an idea whats in the paint.
                    That will give ya a good idea what will cut it, then go to a good automotive paint supply store and ask them.
                    Usually if they know whats in the paint they can recommend a product that will work.
                    Ya just got to find a good one with people who know what they are talking about.
                    T.C.
                    • JimClark
                      • 5907
                      Well seem's like wet sanding is the only good option. Got some of the Citri-Strip and yes it will take fusion paint off but it also softens the plastic so not a good option.
                      So back to wetsanding
                      Billy Graham
                      • roadrashracing
                        • 1462
                        I used goo gone extreme to remove paint on a hatch I messed up on.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2558
                          #27
                          Be careful with brake fluid on plastic guys. I work with this stuff everyday and can attest to it's ability to eat/soften screwdriver handles, pens, pencils, the mouse on your computer, etc...
                          I don't have experience with brake fluid and styrene, but knowing the limited chemical resistance of it, I wouldn't think it would survive too long.
                          Most of the examples I mentioned above are after long term exposure, but only surface exposure, not submerging. It's nasty stuff, but it will completely neutralize/wash away with water.
