Go to www.lightflightrc.com and look at their 380's.They are 4 pole and have an awesome warranty.I might be going that route with mine.Where are you from in MO?
No More Feigaos!!!
Festus for me and johnson.I ran with the Thunderboaters at Holten park this past summer.Good guys to run with.They are mostly nitro and gas,so its easy to impress them with the FE.We run quite a bit in Arnold on the way home from work.(Damn day light savings).Johnson and me run with another member here also.His name is Suckmywake.Really good guy.Maybe we can all meet up sometime and run the hell outta something?Comment
Not jacking at all.Thanks.Your welcome here too.We ll make plans sometime as long as the water isnt frozen.Comment
Looked @ that motor link Larry and service seems promising. Need counter rotating props for this 2 plus footer as well. Any ideas? 30 mm x ?? Still new at FEB.Attached FilesGas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Comment was for Larry's rebuild (if he's now in the mood) but if you have the same hull its an option to use the LBA2860 motors. If the 36mm version motor would fit in yours that would offer you more power but I dont know the physical dimensions of the sponson tunnels to see if it fits. Last thing anyone needs is to have problems removing the motors in as it typicaly makes folks not want to pull them out for regular maintenance. And that is important.
Im still undecided about using the hull itself after the motor thing.Its been through alot and has been repaired 4 times in different places.I might go with the Arc motors later if I keep it.The great warranty has me sold on those and I know for a fact they run good.Comment
