I don't think it's actually a wax. Like you said wax is a good insulator. The process is referred to as a pre-wax. I don't know the actual material. Anyway, that's moot and beyond the scope of this experiment. Just stating that resin casting is a plausible solution and inspection repair is possible in some processes.
Ignition systems use a resin cast to prevent water damage and help dissipate heat. This is nothing new, just being applied to an ESC in this experiment. Some sandbar resistors also use a resin cast to dissipate heat. SSDA
I've worked with plenty of little gadgets over the years that have been resin casted and just don't see why it's not being used for marine ESC's.
I've hooked a fan up to an ESC and kept it cool. That worked well. In fact I'm using turbo fans with ducted cooling on a pair of CC240's in a Sprint Cat right now.
I <3 you guys.
I <3 you guys.
