What to glue abs together?
  • boater76
    • 505
    What can I use to glue/bond abs together?
    Ken
  • Tony
    • 413
    5min epoxy
    • JimClark
      • 5907
      Plumbers goop some use CA also
      Billy Graham
      • NativePaul
        Greased Weasel
        • 2761
        Stablit Express.
        • andym
          More Go Than Show Prop Co
          • 2406
          CA works a treat but makes the ABS very brittle, I have found 30min epoxy great as it is very ductile
          • Alfa Spirit
            • 2131
            Stablit Express.
            +1, perfect for ABS
            • Diegoboy
              • Mar 2007
              • 7244
              BONDENE SOLVENT CEMENT
              A specially formulated solvent cement for fast, permanent bonding of most
              similar plastics, including Styrene. Quickly bonds ABS to ABS, Styrene to
              Styrene, Butyrate to Butyrate and Acrylic to Acrylic. Actually melts the surfaces
              together, creating a bond as strong as the surrounding areas. Full coverage
              attained by capillary action. Comes with applicator brush in cap.
              • sailr
                • Nov 2007
                • 6927
                You need to use a solvent based cement to do the best job. epoxy just sits on top of ABS, it doesn't BOND it. I have been curious to try CA DEBONDER to see how it would work since it contains acetone as the solvent along with a retarder to keep it from evaporating before it has a chance to bond. Methyl Ethyl Ketone (MEK) solvent works the best. It's available at most Ace Hardware stores.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  I have been using medium CA and kicker for years...no problems yet. Depends on the lip. I would consider using the goop but only if I can put it on the lip inside prior to joining. The crap is hard to work with and stringy.
                  I like to use tape first to make sure everything is perfect then tack areas with CA first to hold it. Then I go on around the hull with CA...if I do not have to use kicker then I don't.
                  I have not used the S-express but if Paul says it works well then I would consider trying it.
                  www.rcraceboat.com
                  [email protected]
                  • Diegoboy
                    • Mar 2007
                    • 7244
                    I should have pasted th following text with my 1st post.
