SF esc need help
  • darryl whitman
    • Sep 2012
    • 535
    SF esc need help
    hi guys , I have a JAE 21 FE , 1515 y1 2200 kv motor, SF 220 pro + esc
    an 4s 5000 mah bats, abc 1818 prop .I have a program box for the esc, an I set the timing at 10 deg, what is happening is I start out running strong the 1st
    2 laps then she starts slowing down , when I stop an start up again
    she runs strong, then again slows down after 2 laps ,
    any1 have an idea what is going on , plz help.
  • tlandauer
    • 5666
    What battery? Sounds like the voltage is dropping under load and the ESC is reacting to that. I have almost the same set up as you do but my battery is quite new. What is the LVC on your set up?
      • 8012
      The 1818 is pretty aggressive and loads the motor a bunch, so marginal cells will show depressed voltage after a few laps. That may be enough to prompt the LVC to kick in. I assume the ESC is set to a soft cutoff. If you lower the LVC setting to 3.2 volts that may be enough to finish the heat.
      My JAE with 1415/1Y likes a modded H-7 and runs 12 second laps, GPS in the mid-70s. Less load than the 1818 too, averaging around 100 amps during a 6-lap heat.
      • darryl whitman
        • Sep 2012
        • 535
        thanks Fluid. I'll reset the esc an switch props , what modds to your H7?
        • SirBudman32
          • Aug 2011
          • 625
          I run a CC 1515 2200 with a T-180 on 5s in my Jae turning a 1650 back cut. 86.5 mph.
          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • 8012
            The H-7 is detongued and cupped at the tips to reduce lift. A bit of extra pitch on the last 1/8" of the blade too.
            • darryl whitman
              • Sep 2012
              • 535
              how did you get a T180 esc in your JAE? LOL is your tub widen?
              • SirBudman32
                • Aug 2011
                • 625
                Yeah just a little. But also turned the cooling block on the 180 90 degrees.
