Best Lipos for the buck ??
  • tlandauer
    • 5666
    #181
    @785boats,
    Please enlighten me, the photo shows the top cell gone bad, is this the actual physical size of the blown cell? I know you said that there was no fire, but the expansion would rip the hull apart, am I right? Is this blown cell puffy and soft or solid but just deformed?
    Just curious, sorry for the questions!
    Thanks
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      #182
      Hi there tlandauer.
      Yep. That's the actual size of the blown cell. All it did was rip the velcro hold down straps apart. The cell was soft & as you can see the foil bag was split & you can see all the edges of the laminations inside the cell.
      No other damage to the boat. No fire & no excessive heat. We were in the same race together at the time. The boat just lost speed & so he pulled it into the center of the course while the race continued. It wasn't until the rescue boat brought the boat in that we saw what had happened.
      Baffled the hell out of us.
      Cheers.
      Paul.
      • tlandauer
        • 5666
        #183
        Hi Paul,
        Thank you for the reply. Iam glad the hull wasn't damaged. I had a pair of TP lipo, (2s), forgot the exact name, they went bad quite quickly as well, that was 2years ago, I ran them in my Formula FasTech.
        I admire your ability to doctor lipo
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          #184
          Thanks.
          I've got a couple of packs in the doctors surgery at the moment waiting for an operation. A couple of Zippy 5000mah packs with a cell in each that's got high internal resistance & take forever to balance up. And of course they discharge faster & lower than the other cells under load. So they get hot & puffy. I'll turn them into 3s packs. They will blow if I keep using them as they are.
          Repairing packs gets easier on the nerves after the first couple of times. But always safety first. As an Electrician dealing with 240V, 415V, & sometimes 11,000V, I have a healthy respect for the power of the electron. Even at 3.7V/cell in a lipo.
          • lenny
            • Sep 2010
            • 4294
            #185
            Like this and get the program card if you do not have one,
            Just makes things easier to do.
            ? ONLY IF THEY WORK
            • Jaguar1
              • Aug 2013
              • 39
              #186
              LOL, and here I was waiting on a PM... Just happened to check this thread out again... I haven't seen those with 5 caps before. Will go with it then. The one I'm looking at has 3 on the unit and 4 more in the extra cap pack... Thanks Lenny !
              One more question for you guys, Should I go ahead and remove the stuffing tube on the MG and jump on up to the 3/16's flex cable instead of the .150 with a hot 6s setup and 6000 mah bat's ? Seems like I should...what say you ?
              • lenny
                • Sep 2010
                • 4294
                #187
                When your prop and shaft go swimming you will know,
                .187 flex is what you should be using.
                ? ONLY IF THEY WORK
                • Jaguar1
                  • Aug 2013
                  • 39
                  #188
                  .187 in the cart...thanks again Lenny.
                  • Jaguar1
                    • Aug 2013
                    • 39
                    #189
                    Received my Dinogy packs today from Mark. Ordered Sunday and at my door Wednesday. Cant beat that with a stick.
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #190
                      I've been using Vant packs from Dirt Cheap RC, have not had any problem at all. The price is killer and they perform well. Here's one of the 3s packs they have. http://thebarnfloor.com/catalog/prod...6#.UjiJx9KmiSo
                        • 9488
                        #191
                        thanks for posting
                        • KEEBIBEAR
                          • Apr 2012
                          • 39
                          #192
                          Ok so since Ive read this from front to back Ill toss in my 2 cents. I work at a local hobby store and about 2 years ago I bought 12 yes 12 Thunder Power 65c 2 cell lipos and of that 12, 6 puffed or exploded with lack of anything better to call it. 2 actually burned up while running my UL1 at low speeds with some quick bursts but NO long drawn speed runs. 2 puffed while still in the bags from buying them. They were really cool on warranty sent me another 6 which a couple of the had issues too. When trying to warranty both sets of bad packs I got the your using the wrong charger and you need to use the Thunder power charger we will sell you for x amount of dollars. I used a Ice charger and Team Checkpoint at the time and have a Venom and Hitec now. I still use the Thunder power batteries but do have good luck with Venoms and Traxxas lipos too. We mainly run them in buggys and have a Flux,e-revo and Summit. Id like to think Im not hard on them and dont race. Just my 2 cents
                            • 9488
                            #193
                            Thank you for your input
                            • Accessable
                              • Jun 2012
                              • 57
                              #194
                              Well now I have a total of 6 Thunder Power 6S G8 2700mA 70C LiPo packs.
                              At $170 AUD each here is my report as a consumer:
                              Firstly, I use an Absolut 1807 Dual 300W + 300W charger set at 1C on both channels.
                              It's fed off 2 X 45 AHr Pb Gel Cell batteries in parallel. They are in turn constantly trickle charging from a 13.8 VDC 5A power supply.
                              Charging timeout is set to FIVE HOURS!
                              Maximum charge current is set to 2.7 Amps per channel at 4.2 VDC per cell.
                              I have yet to charge any of the Thunder Power packs without some form of balancer discrepancy showing up i.e. "Balancer voltage too high" or "Time out" occurring.
                              Pack resistance varies from minute to minute from 0mOhms to 500mOhms+
                              I've suffered balancer open circuit after a single run on 2 packs so far.
                              I've had them replaced under warranty.
                              Perhaps it's my charger... yet it has worked flawlessly with many other brands in the past.
                              Can I say I have faith in any of the packs I paid my hard-earned $1000+on?
                              No.
                              Am I asking too much of them?
                              If temperature readings are anything to go by, then again, no.
                              I keep them well below 50c running 12S ie 2 packs in series.
                              My data logging says 100 Amps at best and they've been easy test runs.
                              How to make a small fortune.... Start with a large one and get into FE boats!
                              • Accessable
                                • Jun 2012
                                • 57
                                #195
                                Just lost balancer circuitry on yet another 2 Thunder Power 2700mA 6S G8 packs
                                Bear in mind they do tend to get wet when drive train failures occur (snapping 3/16" flex drives).
                                Oh well - what's another $340 bux...
                                At this rate I might go back to burning nitro.
