Help on battery choice for newby
  • Davidg
    • Jan 2010
    • 6
    Hi i have 29" delta copy with a kb45 08xl 1600kv and a hydra hv 120 esc runing a prop that has 1626 on it is 42mm 2 balde what batteries should i be using and does the rest of the set up look ok.
  • Davidg
    • Jan 2010
    • 6
    can anyone help
    can anyone help
    • BHChieftain
      Fast Electric Addict
      • 1964
      Hi,
      With your low KV motor, you actually have 2 choices:
      1) Run 4S1P with a large prop
      2) Run 6S1P with a small prop
      I like lower RPMs with a larger prop as I suspect parts will last longer.... but it will run slower.
      My Syncron config is simliar to what you have above, except that I have a 240A ESC. I think you'll be fine with 4S on the 120, but maybe not with 6S...
      Chief
      • Davidg
        • Jan 2010
        • 6
        thanks i have a hydra hv 120 esc that can take 50 volts what mah anc c rating should i be using
        • LiPo Power
          DJI Drone Advanced Pilot
          • May 2009
          • 3186
          Higher MAH will give you longer run....
          C rating from 25 = ok power kick
          C rating up to 40 or higher = wicked power kick
          You can use any available to you. Higher the C is, better the discharge will be, its like better octane fuel for your car....
          I have DF-29 and using 2 x 2S lipo batteries, total of 14.8V, some are 20-25C, some are 30-40C....
          Cheers
          Robert
          Canada
          • mappo
            • Feb 2010
            • 487
            Hey depending on the run time you want! i will use a 5000mah @20c the least
            Do you know what the biggest problem with the world is?
            That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
            • Diesel6401
              Memento Vivere
              • 4203
              Get 2 of these each. Open up your options to find the best set-up. That way you can run 4s, 5s or 6s till you find your happy place
              - Diesel's Youtube
              - Diesel's Fleet
              • Dangerous_Toys
                Hiding from the Ole Lady!
                • Apr 2010
                • 2250
                Seems to be a broken link Diesel
                ? WHAT RULES?
                • Diesel6401
                  Memento Vivere
                  • 4203
                  Yea i hit the wrong button and ran two links together try again buddy. I think i fixed it.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Dangerous_Toys
                    • Apr 2010
                    • 2250
                    ? WHAT RULES?
                    • Davidg
                      • Jan 2010
                      • 6
                      thanks
                      thanks for the help
                      • Make-a-Wake
                        FE Rules!
                        • 5554
                        Your ESC may go poof...............the 1600kv KBxl pulls amps like you cant imagine. I've personally confirmed this...............twice.............
                        • Davidg
                          • Jan 2010
                          • 6
                          hi make a wake thanks what sort of amps does the kb45 xl pull sould my batteries have higher or lower amp than my esc is rated as i am now confused
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            I'd run 25c / 5000 mah minimum, you may get away with the 120a esc, but it'll be close.............prop it conservatively and it may work.
                            • Davidg
                              • Jan 2010
                              • 6
                              thanks for the info what sort of amps does the kb45xl pull
                              would you be so kind to help me with a few questions below as the more reading i'm doing the more confused i getting
                              1. does the battery amps need to be higher or lower then you esc is rated.
                              2. with this setup am i better to run higher volt or amps
                              i currently have 2 x 4s 35c 3000 mah and 2 x 4s 4000mah 15c batteries
                              alos would it be better to run in paralell which doubles your amps and run time or series which will double my volts as far as i understand
                              any help would be appricated
