ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1037
    #331
    Here's me fussing with a minor detail. This canopy has a slight twist up, on the front right, and the springs on these latches won't take all the twist out...
    • sammyha
      • Jul 2018
      • 1037
      #332
      I've made springs for one of my RC Crawlers and had spring wire left over.
      Here's how to disassemble these latches...
      • sammyha
        • Jul 2018
        • 1037
        #333
        I found a screw with the right pitch and diameter. Then chucked it in a drill and wrapped a spring around it...
        • sammyha
          • Jul 2018
          • 1037
          #334
          The pencil is pointing to the original .015 wire diameter spring. Below it is the new spring made from .020 wire diameter...
          • sammyha
            • Jul 2018
            • 1037
            #335
            That's lovely, the new spring holds the corner flush...
            • sammyha
              • Jul 2018
              • 1037
              #336
              Well, it's still winter in my neck of the woods and I've been busy. I put together a rescue boat.
              And tested it!
              You'll have to watch this video to find out how that happened up here in the north country in January... [emoji41]
              • sammyha
                • Jul 2018
                • 1037
                #337
                Here's a idea that could be used on all RC boats. Riggers, cats, v-hulls and definitely scale boats of some of those types.
                Check it out, the video explains it all...
                • sammyha
                  • Jul 2018
                  • 1037
                  #338
                  I built a second boat stand. Sometimes you don't get it right the first time. It's ok, that's part of designing something, it's why you have Revision A... and Rev B... and Rev C...
                  Seriously tho, this should work well, it's also why it's good to practice plagiarism, and why copying something is the greatest form of flattery. The design guys are so good at what they do. And under appreciated.
                  Here's a link to a video on my second stand...
                  • sammyha
                    • Jul 2018
                    • 1037
                    #339
                    Detailing the windshield. It's made from airplane heat shrink covering.
                    I used black pinstripes around the edge and a charcoal gray pinstripe for the center bar. The rivets are done with white paint.
                    I pierced the black pinstripes with a #11 exacto knife, twisted the knife and then applied the paint with the knife.
                    I first sprayed the paint onto wax paper, then dipped the knife in it and poked it in the hole until a dot of paint transferred...
                    • sammyha
                      • Jul 2018
                      • 1037
                      #340
                      pla·gia·rism
                      noun
                      the practice of taking someone else's work or ideas and passing them off as one's own
                      "there were accusations of plagiarism"
                      In post #338 I used a word that doesn't represent what I meant to say. I did not know the full meaning and should have looked it up beforehand. "Emulate" would be a better choice of words.
                      em·u·late
                      verb
                      match or surpass (a person or achievement), typically by imitation.
                      "lesser men trying to emulate his greatness"
                      To a large extent that's one of the main purposes of a forum. Sharing information so we can all have greater success in a shorter amount of time.
                      That is rewarding both ways...
                      • ray schrauwen
                        • 9471
                        #341
                        It's been a very rewarding thread, thank you.
                        It you built the 310 like I did would you use sponson safety tethers? What gauge wire would you use if so?
                        • sammyha
                          • Jul 2018
                          • 1037
                          #342
                          Well, thank you. It's been a great experience and I learned a whole lot from you guys and from taking on this project.
                          I guess it depends on what you're doing with your rigger. For a spec boat running laps, maybe they don't want the weight. They do hit buoys and break the booms tho.
                          What's it worth to you? I don't like the thought of flipping it on a SAW run and losing the tub.
                          If you use them, I think the 1/16" galvanized cable I used would be fine for the RSX380.
                          • sammyha
                            • Jul 2018
                            • 1037
                            #343
                            First time this has seen sunlight. I wanted to see how the paint looked...
                            • rol243
                              • Apr 2017
                              • 1038
                              #344
                              very nice . you guys just need a snow burner.
                              • sammyha
                                • Jul 2018
                                • 1037
                                #345
                                Thanks. We have snow to sell. Twenty year record in inches for February...
