Hardware backers:
I hate blind nuts! I do travel races from time to time, and need to remove hardware for shipping. I have found blind nuts always strip out or fall off eventually! Working with washers and nuts in the tight confines of boats is a pain too. For this build I am using 1/8' aluminum plate material. These pieces will be drilled with a #29 drill and tapped with #6x32 threads. The back side of the plates have been scuffed up with 36 grit sander. This is to help the epoxy stick. Once the plates are ready to install, I cover the back side with epoxy. Coat your bolts with some grease and tighten the plate to the hull while the glue dries.
