OK, I removed the sponson assemblies from the build board. I decided to put the rear bottom pieces on the sponsons. I used a sanding block to grind the right angle on bulkhead A lower edge. I also had to bevel the rear of the flat bottom piece of plywood. Parts fit well!
Using the sanding block with 80 grit, I shaped the top and bottom edges of the sponson sheers to rounded shape. Kind of follow the edges of the bulkhead until the block is flush with the top and sides. You will be taking off quite a bit of meat from the outer edges of the sheers.
I then epoxied all the joints of these sponson framing parts with West System. I also use small fiberglass tabs cut from fine cloth. This adds a lot of durability to a wood race boat. More about this later. Taking Mikes advice, I will not install the sheeting untin I mount these frames to the center hull section.
