Yeah I do mean Porpoise ... everytime I type the word porpoise it never looks right ... I guess that's what spell check is for!
Toysport Jolly "magic part"
If any of you guys have bought these hulls from me, let me know. I can get the wedge for you. I have a couple of wedges for Doug P and Robert G going out today.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
tunnel tabs work very well. they have been around since the first cat hullsComment
Yeeehaaaa !
I finally got around to fitting my own version of the 'magic part' to my twin Jolly and what an instant transformation.
No more porpoising what so ever, and she rides perfectly with just a little bit of nose up attitude at full speed ( I'm guessing about 90 kph / 55 mph ) and when she does leap off a wave she stays dead flat in the air.
Who would have thought that such a simple mod would make such a difference.
By the way, rather than use the fibreglass wedge, I made an alloy flap to the same dimensions which is attached at the front edge but is adjustable at the rear ( just like on the full size cats ).
I can move the rear up and down a little but it works just fine at the setting supplied by Joseph ( Mr Toysport ).
I hope on future hulls this wedge is included in the design as it turns a dog into a rocket ship.
Graham.Comment
I would like to discuss the term : tunnelextension , haha
the TUNNEL ends where the sponsons end, so this is not a tunnelextension, haha.
In the latest version of the Jolly, they have made real tunnelextensions.
Note : this is not the Toysport version, but a changed version of the original AS-Schink Jolly.Attached FilesComment
I Loved my Jolly more than any other boat I have and it drove me Crazy trying things to make her stop bouncing!!! I finally read this thread and found new hope. I sent a e-mail to Mr.Toth asking about ordering a wedge for my hull and got no reply... a couple of weeks past by, then I checked the mail box on my way in from work Friday and to my suprise a package was in there for me from Hungury???? 1 wedge and 2 other pieces of odd shaped cutouts, I fumbled around with them for awhile and then it came to me what they were for....
My setup in my Jolly was a125 Cuda, 20 IB 3600, 14XL and a X447/3 it was good for just over 50 mph, I recently put it on 6s but haven't bothered to put the GPS back in it. And if the bounce goes away for good I have a 1527/1D, X450, 240 Hydra and 4s X 2 6500 mAh. My math shows that the 1527/1D will spin about 6000 more rpm and make a ton more power then the 14XL on 6s.Last edited by Tuslow1; 11-15-2009, 03:39 AM.OK, You Go First!!!Comment
100 points ! the odd parts are tunnelextensions.
You will think you've got a different boat, the first time you go out with the extensions/wedge !Comment
I wish I would have asked before I put it together
I used spots of CA to hold it together then went over the seems with 30 minute epoxy... I don't want it to come apart in the water... and yes I put a slight sand scuff on all of the seems before I started.Last edited by Tuslow1; 11-19-2009, 02:16 AM.OK, You Go First!!!Comment
ok, I'm at my nerves ends at trying to get the boat to run properly... I've cut the strut out, moved it up and down with no luck. Added the wedge and tunnel extenders, with worse luck!! after I added the pieces from Mr.Toth the boat ran like total crap!!! I'm starting to think I should have never touched it after all, She did her share of bouncing but it ran over 50 mph. I'm about to give it a total drive make over!!! I got a strudder from OSE and I'm cutting out all of the original driveware but leaving the wedge and extenders, this is my last effort to make her run right... after adding the new pieces the prop sucked massive air and when it grabbed water all it would do is hard righthand hooks and spins!OK, You Go First!!!Comment
personally I think you have to much weight in the hull. why don't you ask MR. Toth what he recommends for a ready to run weight of that hull.l I will bet its way over weight. 4s1p 6500 and that 15271d you have would be a better set up IMO.Comment
Jeepers I now have a 14XL on 6s2p in it and that is way lighter than the 1527 and 2 4s packs...
I think the problem was moving the strut around then adding the addon's plus maybe too small of a prop ( X442 ) it ran it's best (55 mph) with 20 sub-c's and a X447/3 with the 14XL.
Guys told me to raise the strut to stop the porpusing and that was my first mistake, now with the OSE strudder I have easy adjustment, so I think she will be fine.
She has to do good with the current setup before I dump in the big guns.OK, You Go First!!!Comment
Example: Brian Blazer at Blazer Marine recomends the CG at 1" behind the sponsons on his Whiplash 20 with a RTR weight of 5lbs. This changes if the boat is built heavy.Comment
Just recieved my wedge and extensions from Toysport - what is the best method to attach them so they never never come off....anyoneComment
