Old member....new build....scale build...
  • ScarabChris
    • Oct 2010
    • 752
    #61
    Now the USPS tracking says this.....
    "The package is delayed and will not be delivered by the expected delivery date. An updated delivery date will be provided when available"
    The package is delayed.....NO FREAKING S**T! LOL..
    I have seen this massage before, this means they truly have no idea where it is. I can tell by the tracking details that it was routed completely wrong. I have ordered a bunch of times from OSE and I know this is not their fault. Like I said the last order got here in 48 hours from the time the order was placed. This one was placed last Saturday and I paid the extra for the "priority mail" which should have had it here by Wednesday.
    I am fully expecting to never see this order. OSE will likely have to file a claim and resend the order. If it doesn't arrive Monday then I will have to place the order again and ask it be shipped UPS. Then OSE can refund the first order once the USPS pays them for the loss. Or if it arrives after the 2nd order I'll just send it back to them.
    This really sucks.....I was intending to meet up with some buddies Sunday (tomorrow) and run this boat which is why I paid for the priority shipping so I could get it and have a few days to assemble everything. We are now over a week waiting on this. Grrrrrrrrrrr!
    • Beaux
      • Dec 2015
      • 550
      #62
      I just went through the same thing, it's all the holiday mail.
      • ScarabChris
        • Oct 2010
        • 752
        #63
        Holiday mail....naaaa....just the typical USPS way of doing things. In my business I ship packages nearly every day and I am very selective when I use the USPS. They are the cheapest no doubt......but you get what you pay for. I use UPS mostly, they are much more reliable but also more expensive. For every package that gets lost or delayed with UPS the USPS does it 10 times.
        That said, the USPS is usually the better option for small inexpensive items. But I will never send a package valued more than $200 with the USPS, especially if time is an issue.
        Anyway now the tracking says "expected delivery" for today.
        • ScarabChris
          • Oct 2010
          • 752
          #64
          Finally! Big joke though..."Priority Mail 2-Day"
          More like "You ain't crap and we don't care we will get it there sometime between 2 days and 8 days"
          And Steven sure did his part....shipped on the 27th as promised.
          Ok now let me get to work.....
          • ScarabChris
            • Oct 2010
            • 752
            #65
            Welp......it's ready for a test run. Why is my chest pounding? LOL. Going to have a cold beer before I toss it in the canal.
              • 7673
              #66
              Well....
              • fweasel
                master of some
                • Jul 2016
                • 4285
                #67
                Originally posted by srislash
                Well....
                Right! How'd it go? I love how neat everything is laid out inside the hull.
                Vac-U-Tug Jr (13mph)
                • ScarabChris
                  • Oct 2010
                  • 752
                  #68
                  I gotta say....I was impressed. This thing runs sweet, couple of bugs to work out with regard to drive trim angle and steering. But even with the drive trim angle trying to shove the bow into the water the thing was hauling a$$. I think running the larger props than what the Graupner drives had really made the difference.
                  The props are 5517/3 (heavily worked) that I got from Chris (Dasbota) many years ago but never used. They work perfect on these AMPS outdrives.
                  I had to pull one drive apart, I could tell one of the gears was loose. I could spin the prop a 1/4 turn while holding the motor shaft still. This is what cut my testing short, I would do a couple passes and bring the boat in to check things and after the 3rd pass I found the loose gear so instead of taking a chance of it coming more loose and stripping it I brought it in and tore the drive apart. It's all back together now and just as I though the set screw on the top input shaft gear had backed out allowing the gear to rotate a little on the shaft.
                  Overall I love these drives, very smooth and quite, not a drop of water in the boat. The Graupner drives...the way the shaft and steering was the water would leak in like crazy. The hull was bone dry even after floating in the pool for 20 minutes AFTER the run.
                  The only thing I don't like about the outdrives, need a lot of space to turn. No sharp turns with these drives, my canal is only about 50' wide and its lined with boats on both sides so to turn around it's close. But it's to be expected with the power passing through a U-joint, and out in open water it won't be an issue.
                  I'll get some running video this weekend.
                  • Newboater
                    • Jul 2016
                    • 359
                    #69
                    On the turn around couldn't you use just a little reverse to give yourself some extra room if need. By the way beautiful looking set up. Would love to see a video
                    • ScarabChris
                      • Oct 2010
                      • 752
                      #70
                      Yes of course and I had to do it a few times when I thought my loop was getting close to a docked boat. Just have to bring it to a stop, turn wheel in opposite direction and back up.
                      What would be really cool......and it probably exists.....is when turning to full lock the inside motor slows down giving the outside motor the ability to help the boat turn sharper. I do this every time I turn my real boat into the canal, it's a tight turn so I pull the inside engine to neutral and give the outside engine a little more throttle which helps whip the stern of the boat around the corner.
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4285
                        #71
                        Yes, very cool
                        • ScarabChris
                          • Oct 2010
                          • 752
                          #72
                          Working on the GoPro mount now. I want to get some up close video of the drives and exhaust (cooling water discharge) at high speed. I also have an extension so I can point it forward and see over the bow.
                            • 7673
                            #73
                            Just need a channel mixer, ask Craig where he got his. I had one made for me but it was like $50
                            • ScarabChris
                              • Oct 2010
                              • 752
                              #74
                              Got an onboard video of the drives. I took a forward video also but it didn't record for some reason. I may have not held the record button down long enough when I got it going. I'll get another couple videos this weekend. I'll get the wife to record it and I'll get a forward facing onboard video.
                              I need to move the trim tabs up a little, they are "scooping" water and throwing it all over the place.
                              Look at the amount of cooling water coming out of those faux exhaust pipes....dayum! LOL.
                              This boat is FAST! I adjusted the drive trim but now they are a little high, this thing gets squirrely at 3/4 throttle. When at full throttle it's riding on the 2-3 inches of the keel. I'll put my GPS in the next run to get an accurate speed but I would guess an easy 30 MPH. This video does not show full throttle. I did the full throttle runs on the forward facing onboard video that didn't record.
                              Drive height on the transom is good though as you can see the cav plates fully out of the water.
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4285
                                #75
                                That's one of the coolest RC boat videos I've ever seen!
