BBY SS-30 Sport Hydro "Orange Crush"
The Popeye is a different animal than this I would think being it's hull design is a good 40 years old. The Popeye packs a lot of air compared to this hull. Hopefully you don't burn anything up. I'm not slammin, just talking too much. With the popeye, you would have the prop high loke Doby correct? If so you would only be riding on the tips of your prop not a larger portion like you might on say a Whiplash or maybe this hull. I don't know Randy's hulls too much, only had an old Volcanic splash that was really cool.
Randy, what say you on prop choice? Am I way off here? I thought at best a 1y would only push up to a 45mm prop but, that depends on the prop and lots else like hull design. Maybe it's a 645 I was told, never mind I'm rambling because Larry is late and I'm Hangry.Comment
yeah, with the rails running all the way to the back and the ratio between length and sponson width along with tunnel width help the Popeye pack lots of air all the way to the transom so it's easy to run a large prop up high like that. I like the popeye in aesthetics but, I looked at it and said, something tells me it was designed to use less power and be rock stable doing so. I think that hull would max out at 45mph in oval trim. Nice boat but, more sporty than race ready.Nortavlag Bulc
yeah, with the rails running all the way to the back and the ratio between length and sponson width along with tunnel width help the Popeye pack lots of air all the way to the transom so it's easy to run a large prop up high like that. I like the popeye in aesthetics but, I looked at it and said, something tells me it was designed to use less power and be rock stable doing so. I think that hull would max out at 45mph in oval trim. Nice boat but, more sporty than race ready.Comment
That was you huh, imagine that. I saw your mods and then I said I'd try a ML or another Whip 20. As much as I curse while doing it, I like building wood boats.Nortavlag Bulc
and I'll rig it when it gets here
I got a idea to do a set of BBY graphics in the Orange Crush theme with what you have going on any way. I am doing the outline in green and back ground in white . If the green is not the correct color I am sending black and white too.Comment
That sounds Killer Randy, Are you making them to go up on the Sponsons? Cause I have Mono Jeff doing the Orange Crush Logos to go in the area back on the deck.Comment
Randy, Which ever size decal White with Green outline you think would go best on the SS-30 is fine with me! The bender I use is a little bender for doing stainless nitrous lines and it's like a mandarel bender, it makes a nice uniform bend without making the tube oval. With everything greased up when you let off the throttle it will actually coast a little instead of dead stopping like most do but thanx for the advise.Last edited by flraptor07; 07-11-2014, 07:33 PM.Comment
I cannot wait for a video of this one!
awesome looking flake !!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
