Livewire's EKOS Build
Thanks Chris. Once I have her trimmed I'll really start to push herHPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
Thanks Joel! The sad thing is my friend lost his Revolt 30 yesterday, she sank 30 feet from shore. Time to plan a salvage mission.HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
Here's another video running the Prop Shop 42mm 1.7 pitch props. She's had the trim done and she's running perfect!
So you have two seaking 180's, but what motors are you using, and are you still running the stock flex drives?HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
I'm not familiar with the m545 outrunner, what's the kv rated at?HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
Lol! Since your limited to 6s with that esc, you could try propping up to a X646 or a X648. But you're going to have to be careful, start with the X646, and check the temps after the first minute, then after two mins and so on to make sure everything is ok. If the temps are ok after that, then you could try going up to the 648, and then repeat the temp check again. The 646 will get you close to 60mph and the 648 will get you over 60mph. Maybe someone else can chime in on this, as I don't have a lot of experience running outrunners.
RichardHPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
The 5 stands for 1.5 pitch 46mm (546) and the 6 stands for 1.6 pitch 46mm (646)HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
