Thanks, I can definitely say the extensions are attached extremely well. When I was mocking them up I was also polishing/sanding them. The tolerance in the support to the extension mount was pretty tight. With some grit and polish the mount pin got locked in the extension. I literally had a long screwdriver in the stinger slot with the whole boat locked down with my legs wrenching on it. The more I tried the tighter it got!! I finally removed it and had to drill/mill it out and make a new shaft!! At one point I thought I might bust the back of the boat apart, that's when I stopped. Inside the hull I made a "H" shaped plate for the bolts to go into, and tapped. That was very hard to get in there!! Absolutely no room. I had to resort to using a scope inspection camera to help line things up before securing with epoxy. Guess the reinforcing is working.
I've been stuck with work this week and don't think I have time for the water but am eager to get back to some speed!!!
