They are, and yes that will get done.
Zonda gets a face lift.
This topic is closed.
Nice Zonda cat Twisted :-) . sorry I missed your thread till today :-) . Zonda Design's some sweet road race cars too. I have a feeling the Zonda may run real wet with 4 lipos in it, especially with 2 in the back. I haven't had any luck running cats with lipos too far back. They seem to prefer the cells up in front of the motor (s) with the prop running +, to get the now p just a bit.....Comment
check this out. 6s batts in the rear of the motors
twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
Thx
[QUOTE=nemz305;538888]nice build. love the color as well]
I have added some new props to try as well. I will be adding some bigger esc's so that 8s is possible.
I my try the esc's I have now if I can figure out how to get past the shut down that happens when I try then on 8s.
large scale rc 006.JPGlarge scale rc 007.JPGlarge scale rc 008.JPGlarge scale rc 009.JPGtwissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
25602.jpghttp://hobbyking.com/hobbyking/store...P1_4_3x3_.html 25601.jpg
You will need to use some drill bits and drill out the center to the size you need as they are 4mm. Work your way up and don't try to do it in one try or you could get of center.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
These will be going in as soon as they are available to me.
here are the specs.
Programmable Settings:
Reverse Type: Reverse lockout, forward only, forward / reverse*
Motor Direction: Normal*, reverse
Reverse Amount: 25%, 50%, *75%, 100%
Starting Power: Low, normal*, high
Voltage Cutoff: Lipo 3.0V per cell, NIMH 40% of power up voltage
Motor Timing: Low / normal / high*
*Default setting
Specs:
Motor Type: Brushless, sensorless motors only
Input Voltage: NIMH 15-33 cell, Lipo 6-12 cell
Operation Current: 200A Cont, 250A peak
BEC: No BEC, seperate BEC required
Thermal Protection: 95°C
Lost RX Protection: Delay 0.5 second
Dimensions: 115 x 50 x 31.5mm
Weight: 290gtwissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
What Size?
