thanks for the info. I have some supplies on order so I have a little time to decide how I'm going to do it
Darin's Phil Thomas Stealth Build
Dang... I just found this thread again and realized I hadn't updated it in a LONG time...
Here is the quick update...
I HATED this boat... I couldn't make it work at all...
THEN, after changing everything and reworking everything... decided that it was likely the turn-fin causing issues.
I purchased a Sport 21 fin from Mike Hughes, and carefully installed it, and THAT fixed the problem! Boat runs GREAT now. Needs the 4S pack all the way forward, and offset to the left, but it works great...
And THEN.....
At the PSFEMBC race this past weekend... DANG it was running well... and then... well... I have some repairs to do.
The damage is fairly localized, and I think I can fix it nicely... Just more time away from other projects.
Repair updates to follow...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Oh boy, i should have put that ply transom all the way across. Looks like the boat just missed it on both side, it will fix ok just done add much weight back there.Comment
Attached FilesLast edited by detox; 05-13-2014, 09:53 AM.Comment
Time to start the repairs...Darin E. Jordan - Renton, WA
at least you didn't loose the turn fin...my whip blew over a few weeks ago in fla and the same guy that always runs over someone every race t boned me taking the turn fin and bent the rudder like yours....it just didn't get the big holes ..... I know you will get her up and running just as wellMY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
I'm a little surprised at how "dry" this layup is. There is some dry cloth around the transom areas. Might have to have a chat with Phil.
I'm thinking of ordering another one of these for another application. I really like the boat now that I have the handling figured out. The Version 2 would likely be the way to go.Darin E. Jordan - Renton, WA
Roughed in the pieces from the hull I got back after the "incident", and started working on fitting the Carbon Fiber plate to the transom. Will cover the "ugly" parts and provide a flat and solid mounting surface again.
May also help protect against errant Insane FE30 attacks...Darin E. Jordan - Renton, WA
