MHZ Mystic 1380mm build
  • Chrisg81983
    • Jul 2011
    • 1556
    #106
    I got the 2240/7 they are 2114 I got the 6 connections on back as well
    • Chrisg81983
      • Jul 2011
      • 1556
      #107
      And yes I got a pair forgot to answe that one
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #108
        Well, awesome!! If you build it right and get it setup right, you have enough power to push this way over 100mph. Should be nice.
        Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
        "Follow someone's footsteps and you will always be a step behind"
        • drwayne
          • May 2008
          • 2981
          #109
          re pm cf+2pk e.
          Hey MrK .. will try to visit Tues, will call first c where u are.
          MrW
          • Chrisg81983
            • Jul 2011
            • 1556
            #110
            That was my goal but most of the time i would like to keep it around 75 mph on 5s the then when desired step it up to 6s and then really be moving but I will do a build thread once it all gets here for now I will be watching yours Thanks Chris g
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              #111
              Just a couple more images of the "little machines" with the thrust bearing installed. I love the look of the Lehners already!!
                • 7673
                #112
                They do look size appropriate in there.Mounts look good Kent.Or is it Trent .
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #113
                  They do look size appropriate, but not PHAT LOL. Let's see if they got the power to get anywhere.
                  Trent
                  • jkr
                    FE Addiction
                    • 568
                    #114
                    If you run over 30.000 rpm your thrust must be ceramic.
                    • Chrisg81983
                      • Jul 2011
                      • 1556
                      #115
                      Thanks for pointing that out you gotta love spell check on these new phones I do that about 20 times a day lol
                      • jkr
                        FE Addiction
                        • 568
                        #116
                        Ooops!
                        • jkr
                          FE Addiction
                          • 568
                          #117
                          nata2run
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #118
                            Originally posted by drwayne
                            Ghris, meet Trent... or is it Chris meet Kent .. I dunno...
                            2 things Kent
                            you need compressed air to blow out every bit of carbon dust from inside else the motors will ingest it, and get belly ache.
                            2nd thing.. do the air trick twice .. just to make sure.
                            W
                            All cool, will do and do regularly as well. What I ment to say with the carbon was... that I mixed some carbon dust with the epoxy (looks cool) and may be stronger dunno. Once im done drilling I will clean the hull inside in methonol. (and then blow compressed air again)
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #119
                              The Doc. came to the rescue again today. He happend to have some CF cloth I could use. (Very minor amount used)
                              Wanted to get something strong for the tubes,s so got them wrapped in CF. Ideal would have been heat shrink and then get that to clamp around, but didnt have any big enough so used some cling film to wrap around as epoxy is setting off.
                              Many hours sanding and then polish should look nice. Here they are before applying the epoxy.
                              • drwayne
                                • May 2008
                                • 2981
                                #120
                                hahaha
                                nice
                                you could have asked this electronics engineer for heat shrink...........ya dope !
                                Ive got miles of it ( literally )
                                W
