maritimo twin cat
  • bonewar
    • Jan 2008
    • 549
    #31
    props from cmdi
    I'm a happy man, i just received my prop order from cmdi(www.cmdracing.com). i would like to thank Donna and Andy for these pieces of art. the props are octura x 442 sharpened and balanced , cupped and detongued, left and right rotation, they should make this cat rock.
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • revin9k
      • Jul 2007
      • 7
      #32
      all i can say is WOW. one day i hope to have a boat this nice. good info and pics. cant wait for video
      • bonewar
        • Jan 2008
        • 549
        #33
        update 3
        OK I've finely got all the components together pic 1,2. the boats transom is going to be modified a little to suit the rudder set up , I'm going to make the pod out of carbon plate then glass the hole piece as 1 back onto the hull. once i have done this i will be adding the motor mounts and the rest of the components. post more pics when complete. o yer i bought this little radar gun to clock my sv27 and the cat. Has anyone used this type of gun.
        • Eyekandyboats
          • 1921
          #34
          have you thought about putting the packs in the sponsons.
          i know from experience that that boat will have a hi C of G especially with a twin setup.. might want to chew on that idea?
          also one other thing , i have found. even with a twin setup that steering is hard. there is either NO steering or ALOT. very little in bwteen.
          one way to correct this is to mount you rudder close to the LEFT prop. Yes it sounds weird but it does work. it will look odd but it will handle and run much better.
          EYEKANDYGRAPHICS
          www.rclipos.com
          • Mich. Maniac
            Banned
            • 1384
            #35
            Having built and now running one of these pretty much exact I can state "these are not Jolly Cats" I dont get any of the porpuising at all and the way his and mine are setup cog is not an issue. It turns as flat as can be even at very high speeds. Turning is smooth and very reactive at low or high speeds despite twin props. In my opinion and seeing what I have the H&M hulls are better than Toysport in those regards. I am amazingly happy with mine however, the difference in driving a cat and mono is much greater than I had realized. On top end speeds I do feel the Toysport Jolly cat may have the advantage but I am only a few runs into mine and still getting prop size figured out. So far I am thinking a set of x447's may even be not enough running 8xl feigao's and hydra 120's. My highest temp after 5 minutes of run is 115 on esc's and packs are 92 degrees.. Havent gps'd yet but compared to a 46mph sv I would say im still in mid 50's.
            • Eyekandyboats
              • 1921
              #36
              what do you mean
              "no jolly cat"??. is this a new term i have never heard of before?
              EYEKANDYGRAPHICS
              www.rclipos.com
              • Mich. Maniac
                Banned
                • 1384
                #37
                • Mich. Maniac
                  Banned
                  • 1384
                  #38
                  what do you mean
                  The Jolly Cat remark was simply that I dont think these will get the same speeds that a jolly would. RC prince I believe said with 8xl's and hydra's he was running 62mph with 438 props I think and I am up to x447's and only see mid 50's but again, I have yet to gps. As far as the C.O.G. I dont understand why your sooo worried as from port to starbord these hulls dont seem to lean into a turn at all like the blackjack hulls and as far as bow to transom I think he has it right cause that is where mine is and it rides perfectly aired out with plenty of adjustment if needed and they are similar in setup in that regard. How many cats have you built? I know the M1 you have fly's but wondering if you have built a twin hull of this size?
                  • Jeepers
                    • May 2007
                    • 1973
                    #39
                    Maybe your prop size is why your only seeing 50mph. Too much prop?
                    I would like to know how your temps are cool on x447' with those motors, my expereince with 8XLs is they dont like that much prop.
                    I tried a 445 on a 8xl in a much smaller lighter hydro and the boat was slower than on a x440. and temps were high.
                    Fluid told me this awhile back," an 8xl on an x440 pulls somwhere in the neighborhood of 80+ amps"
                    • Mich. Maniac
                      Banned
                      • 1384
                      #40
                      Dont know, build one and let me know
                      my sv runs 8xl with 45mm prop and works great. Peak amp draw is 102
                      • Eyekandyboats
                        • 1921
                        #41
                        Oh alright Jolly, that toysport hull....... okay thanks for kinda clarifying that.
                        i have built 7, if you read my above posts i said that allready.
                        EYEKANDYGRAPHICS
                        www.rclipos.com
                        • Jeepers
                          • May 2007
                          • 1973
                          #42
                          I have a better idea, you a built it you try it........
                          Twins in a 34" cat.... not worth it for me to build hull would have to be 45"+ for me to build it with twins.
                          you seem kinda jumpy when someone offers advice, if you dont like peoples advice especially Taylors ( I believe he has built more boats than you own) dont post a build thread.
                          • bonewar
                            • Jan 2008
                            • 549
                            #43
                            update 4
                            OK the next step was to make a pod out of carbon fiber plate to match the new rudder system (pic 1) i then cut 4, 35mm pieces of aluminum thin walled pipe to hold the rudder (pic 2,3) the inside of the pod will be glass to make it bullet prof , then it is time to cut the back of the hull and glass the pod in place. water cooling for the cat , i bought 2 large water pick ups from MHz (pic 4,5), i cut the nipple off the pick ups then drilled a 4mm hole and added a 30mm piece of thin walled aluminum pipe, makes the intake of the pick up about 1.5mm bigger. (silicone tubing id is 4mm,metal clamps to hold the tubing) then the hole cat will have the silicone tubbing for better water flow. next week should be very interesting , i will have the pod glass on the boat , then the rest of the gear will go in . post more soon
                            • rcboatfan
                              • Aug 2008
                              • 253
                              #44
                              very nice build
                              SUPERVEE 27 37'' TWIN CAT
                              • bonewar
                                • Jan 2008
                                • 549
                                #45
                                carbon pod
                                The pod. well Ive glass the back plate onto the pod , i think 1 more layer of glass should do the job, it will be bullet prof when I'm finished. the hard part ! cutting this beautiful hulls back off, but i think it will come out real nice, I'm going to try and keep the carbon looking real clean. so i have the option to leave it as is,or paint it white like the rest of the hull. Will have this done soon, finally some time off work,so down the shed i go. :rocking:
