Wow nice paint scheme ! Personally if it was me I would leave it for a day or 2 to harden
Aeromarine Titan 29" My 2nd build
Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx. -
I just ordered a few more goodies to make up a reasonable order with the cooling jacket. I got the b&s m545 to try otherwise I have a a x640, x642, x440/442/445. I also got a m447 but I think I'll be useing that on the 35" pirate.Comment
I'm making progress with my painting attempt, I thought I'd share a few pic's of the color's be I give it a lite rub with wet 1200 paper and add the decals and clear coat. Should I wait a few days for the paint to fully harden b4 taking the next step or should I just get it done now, the paint's been dry for about 3 1/2hours??
Nice paintjob!
Reminds me alot of my Vintage Latrax Cigarette boat................did this scheme about 2 years ago.................Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
OMG, is that cherry red with metallic charcoal I'm seeing there? Gee it's hard to be original when ya come into a hobby so late. Well done, it looks great!
Attached another Titan 29 paint scheme. I own 2 and I am very happy with mine.
Keep up your good work. Regards
Norman2Attached Files34" Ekos Cat UL-1 PoweredComment
thanks for the nice feedback guy's. I got the lid sprayed and some electronics done today so I'll wait until tomorrow before I get the hull ready for the clear coat.Comment
You will probably want to stay away from your bigger props. I basically had the same setup with a CC Hydra 240 and my caps ran pretty warm, too warm for the summer. My final prop was the 440 3 blade..Mine ran 53 mph and looked as if it could handle more speed. Your hardware setup will determine how fast you will be able to take that boat......Like Fluid says , it does run light....Here is a couple pics of mine. If I built this boat again I would use my own motor mount and put closer to the transom, run a offset rudder, use ''Super epoxie" and build my own turn fins from 2mm CF.....Basically how I am doing the Rico...ha ha...My old Titan was able to handle 50 + with never a blow over in semi calm weather ! If you want a link to the vid I can do.."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
You will probably want to stay away from your bigger props. I basically had the same setup with a CC Hydra 240 and my caps ran pretty warm, too warm for the summer. My final prop was the 440 3 blade..Mine ran 53 mph and looked as if it could handle more speed. Your hardware setup will determine how fast you will be able to take that boat......Like Fluid says , it does run light....Here is a couple pics of mine. If I built this boat again I would use my own motor mount and put closer to the transom, run a offset rudder, use ''Super epoxie" and build my own turn fins from 2mm CF.....Basically how I am doing the Rico...ha ha...My old Titan was able to handle 50 + with never a blow over in semi calm weather ! If you want a link to the vid I can do..Comment
Don't lauph at my nareration, I had just sold the boat to a friend and got excited for him and tried to keep him from crashing it...ha ha !....He was running my batts in it !http://www.youtube.com/user/rrandydduke#p/u/LXUVom1naA......this is the link to my channel...find the " file 0068 mov.'' on the play list. 53 mph Titan !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
looks good, ride high and seems stable, I hope I get mine to do the same, thanks for the linkComment
I have a Medusa 3670 2300kv in mine and I will look into running a X440/3
mine just wants to lift above 45mph+.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
flotation foam in the forward section of the hull. Just so you will not loose your
boat should you have a spill. Regards
Norman234" Ekos Cat UL-1 PoweredComment
