suggestions for a boat build
  • carlcisneros
    • Jan 2010
    • 1218
    OK folks, here goes.
    I have a choise of either building the JAE 21 rigger and putting the Faegio 540 9L with 3s 5000 40c in it OR maybe get a Mono hull.
    This will be just for sport running when not running the nitro boats.
    Any suggestions/ comments?
    Carl
  • westbeach
    OSE Rocks!
    • 951
    You can get great speeds out of a JAE rigger, but it depends where/what type of water conditions you're going to be running. This is based on spec setup. Nothing fancy - UL1 motor/esc, and 4S I believe.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • carlcisneros
      • Jan 2010
      • 1218
      what i will be using is above.
      I already have a CMB21 VAC powered JAE and it is a great little boat.
      just need suggestions is all.
      thanks
      • Chuck E Cheese
        • May 2008
        • 1684
        i have 3 jae fe's, one 21fe with a neu 1415, one with the ul-1 motor/esc and one 12 that was converted to fe. the 12 is my fav running a ul-1 set. i just extended the tub upwards to make it as tall as the 21fe and it worked out good. otherwise the stock 21fe is a great boat. both of then run about mid 50's with stock ul1 motors on 4s. as you allready know you cant go wrong with a jae rigger. otherwise the mono will prob run mid 40's on a 9l 3s, i would recomend a delta force 26" or the copys are cheap (around $65 plus shipping). the real delta is worth the extra $ if steve has them in stock
        see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
        • steve-b
          • Mar 2010
          • 245
          Id go with the JAE 21.
          Although it is an easy build, you could spend some time laying down a really cool paint scheme if you want the project to last a while.
          • carlcisneros
            • Jan 2010
            • 1218
            looks like i will be getting a DF 26 from OSE.
            Carl
            • Chuck E Cheese
              • May 2008
              • 1684
              good choice
