Rumdog's Sprintcat rebuild
  • bustitup
    • Aug 2008
    • 3071
    Originally posted by Fluid
    It should be quite a monster on 8S, considering how that hull runs on 6S. Put a 3/4" air dam 3" back from the front edge of the tunnel and move the CG forward an inch.
    Any pictures of this air dam Jay?
    • DISAR
      • Aug 2007
      • 1072
      Very nice job and unique. What is the length of the struts, transom to end of strut? How much is your weight rtr?
      You prefer it like this or with the 1527?
      http://www.rcfastboats.com/
      • Rumdog
        • 6453
        Thanks for the compliments guys! Disar, Not sure which setup I prefer yet. I need a little more wheel time to get this setup dialed. I'm guessing that this setup will be more fun to run, and also easier on the equipment. Everything ran exceptionally cool. The 1.5d was a pretty hot motor and I felt I was pushing that setup pretty hard with the x455. This twin setup id going to be MUCH faster. Hoping to get her wet again today.
        • Rumdog
          • 6453
          I'll check the strut distance for you later. They are the speedmaster .21 struts with the mono brackets from OSE.
          • DISAR
            • Aug 2007
            • 1072
            Ok many thanks
            • Rumdog
              • 6453
              Disar, the struts are 2" from transom to the end of the strut. Ran again with the neg. angle in the struts. It stayed glued to the water. Perhaps a little too much though. Going to adjust them up just a touch. About 2 mins in, one motor cut out. Seems that a solder joint on the circuit board of one of my Turnigy packs went bad. Has a slight burned smell too. That pack is trash I'm assuming. Going to get the Flightmax 40c 5800's. I did gps it today and got 70.4 mph! Pretty dang fast! I still can't believe how well it will corner at that speed. I'm down now till I get new packs though. I have a pair but they are only 20c, and I'm not risking it.
                • 8012
                No picture needed. Cut a piece out of a pool noodle 3/4" square as long as the tunnel width. Glue it to the tunnel floor and sides with ShooGoo. Let dry. Voila.
                • bustitup
                  • Aug 2008
                  • 3071
                  #23
                  OK I think I get the pictue....this is to stop air lift in the tunnel?
                  • tth
                    • Apr 2008
                    • 1510
                    #24
                    Reduce the lifting effects.
                    • DISAR
                      • Aug 2007
                      • 1072
                      #25
                      70 mph!!! Very nice, well done. A very good racing boat, good top speed and good cornering.
                      How many amps do you think each motor consumes?
                      Thinking of making one of my sprintcats twin now like yours
                      • Rumdog
                        • 6453
                        #26
                        Got my new batteries ordered. Hopefully they ship out soon. HK has moved their warehouse and are a little behind. So, question... Paint the hatch, or no? If not, I'll just touch up the existing job. I looks pretty good with the contrasting colors I think.
                          • 9488
                          #27
                          This same thing happened to one of my 3s packs, and it was an easy fix.
                          runs like new
                          70.4mph!
                          • Rumdog
                            • 6453
                            #28
                            I still have the pack. Have been thinking about soldering it back together. Just wondering what caused it in the first place. On a side note, I'm thinking of having my 447's cut down to 455's, maybe pitched up a bit too. I think I'll run the 447's once bfore though. It should be insanely fast!
                            • crabstick
                              • Jul 2008
                              • 954
                              #29
                              Just scored myself one of these hulls!
                              Matt.
                              FE, Nitro and Gas racing in Auckland
                              www.rcboats.co.nz
                                • 9488
                                #30
                                Mine looked like it had a thin solder joint..
