Carbon Fiber 4S Rigger
Why the cooling? Is there so much friction that the shaft overheats and melts the epoxy? What's the RPM?Support US hobby suppliersComment
Non Teflon setup a little over kill to keep the epoxy cool and hard. Epoxy softens at 180 degrees the stuffing tube will move then and cause more friction. It keeps the shaft in the correct place at 45k to 55k rpm. Mostly this is used for 1/4 flex shafts and high reving 3/16 shafts.Comment
Little up date on the boat. I am in the process of re tooling the deck mold to have the drop down included on the mold and clean up a little.Comment
Non Teflon setup a little over kill to keep the epoxy cool and hard. Epoxy softens at 180 degrees the stuffing tube will move then and cause more friction. It keeps the shaft in the correct place at 45k to 55k rpm. Mostly this is used for 1/4 flex shafts and high reving 3/16 shafts.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I have..... just a safety thing to be 100% sure. Ya know cross your tees and dot your I's. I have never had a problem ever with cooling on the stuffing tube. It stays ware I put it. JB weld has to sit for 20hr. too!Comment
I have been thinking about trying a rigger. i have not owned one yet. could you just do the hull and sponsons in carbon, and i'll do the rest? basically supply me with the three major pieces. I imagine this can be wet sanded and buffed out if i wanted just a carbon look? thinking about a 26"(ish) version.....pm me a price if you dont mind.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
O i understand totally.
This is the 34 oval.
