View Full Version : Battery test somethig of interest
EPower
08-28-2009, 01:27 AM
Hi i just did a static amp draw test, i have,been running Rhino 6s/3700 mah/25c discharge batt in my Yak 54 .40 size, i also have two VX G3/6s/5500mah/35c Hyperion batt,using my eagle tree datalogger i did an 8 second amp draw test at full throttle to make sure my 80 amp Titan esc could handle the 35c batteries and was surprised at the results
Rhino 25c
max amps 68
max watts 1627
used 98 mAh
Hyperion 35c
max amps 65
max watts 1548
used 138 mAh
:w00t: Go Rhino :thumbup1:
ED66677
08-28-2009, 02:54 AM
Rhino are good, the voltage under load remains very high, I first tested a pair of 2S4900 last month on my 29" DF copy and the ESC (cheap chinese) cutoff wouldn't trigger, got back home to check everything each cell was 3.52-3.62V and I put 4600mA back in, I know this is way too much but cutoff did not trigger because the the remaining voltage!
DISAR
08-28-2009, 04:33 AM
Better to do the same test also in action. The amps draw depend on the amps request. If no more amps are requested by the motor then no more are delivered.
The amps that you mention will definately go up when in real action.
EPower
08-28-2009, 05:29 AM
Hi i'm flying tomorrow i will run the datalogger in the plane and get some readings see what's its doing :thumbup1:
