View Full Version : JB weld on the flex
FE_Chris
07-28-2007, 08:26 PM
All I had to glue my flex into my stub shaft was some JB Weld. I would think it should hold fine. I just wanted to check. Anyone?
NorthernBoater
07-28-2007, 11:30 PM
I do not see any problem with it. I glued my motor mount in with it. Make sure you let it cure for at least a day before using it. If you are worried that it may not hold you could also use the carbon fiber prop for the first 10 or so runs. This way if it falls off you won't be out a metal prop.
FE_Chris
07-29-2007, 02:55 AM
Thats what I am gonna do...it was pretty good on a x438, but the only carbon I have is a 35 and a 40MM. I'll try the 35 first.
