View Full Version : Caps for esc's
08-18-2009, 02:39 PM
I'm looking to carry some of the caps for esc's. Which ones are you guys using?
kevinlew211
08-18-2009, 02:52 PM
Rubycon 63V, 220uf, max temp at least 105 Celsius
08-18-2009, 03:20 PM
Kevin which esc's are you using them with?
kevinlew211
08-18-2009, 03:26 PM
I personally using Schulze 40160 escs, but that cap will be comment for all HV escs, and you should get some 37v caps for LV escs as well.
kevinlew211
08-18-2009, 07:06 PM
any difference if ....let say between 5 of 220uf cap and just one 1100uf cap? which way is beter way beside the cost?
Ub Hauled
08-18-2009, 08:29 PM
redundancy... if one 1100 cap goes, that's i for your ESC... if you have many smaller ones, a couple can go and may still have an intact ESC
kevinlew211
08-18-2009, 11:20 PM
so let say i put many extra more "uf" caps is it even beter or have to be exactly "uf" of the original one?
knpc
08-18-2009, 11:39 PM
On my CC Hydra 240s i'm using 4- rubycon 35v 470uf high temp capacitors. I put them on after the stock ones failed and haven't had any problems since.
domwilson
08-19-2009, 12:52 AM
Putting more caps in parallel will lower the ESR (Equivalent Series Resistance) of the cap circuit. The drawback is increased realestate that the multiple caps will occupy.
In addition if you are just adding caps, your not boxed in to just using Radials. You can use axials also.
6S HYDRO
08-19-2009, 01:31 AM
I just found 1000uf 35v caps at radio sack, 1.59 each. I put 2 on an a.c. Esc and and now it hasnt got hotter than 105 degrees
tylerm
08-19-2009, 04:06 AM
35v 470uf are good. Yea 105*C temp is good. Also maybe the same ones that come on the castles for straight replacement.
longballlumber
08-19-2009, 08:08 AM
These are the ones that I bought for my ESC's. These are the same series (ZLH) that are on my castle controllers, with a higher Micro Faren (uF) number. Just another note, I don't run anything that is over 4S.
http://www.newark.com/rubycon/25zlh1500m12-5x20/aluminum-electrolytic-capacitor/dp/38M3253
For what ever reason, the higher voltage caps (35V and above) are all shipped out of the UK. The shipping charges are much higher...
http://www.newark.com/jsp/search/browse.jsp?N=500003+1000115+120922+175351+175256+5 017815+5017775+5017756&Ntk=gensearch_001&Ntt=rubycon&Ntx=&No=0&getResults=true&appliedparametrics=true&locale=en_US&prevNValues=500003+1000115+120922+175351+175256&originalQueryURL=http%3A%2F%2Fwww.newark.com%2Fjsp %2Fsearch%2Fbrowse.jsp%3FN%3D500003%2B1000115%26Nt k%3Dgensearch_001%26Ntt%3Drubycon%26Ntx%3D%26No%3D 0%26getResults%3Dtrue%26appliedparametrics%3Dtrue% 26locale%3Den_US
domwilson
08-19-2009, 11:45 AM
You can also get caps from MCM Electronics, DigiKey, Parts Express, Mouser Electronics, etc.
