View Full Version : 53.1 mph stock UL-1
6S HYDRO
08-15-2009, 07:27 PM
GOT SOME GPS PASSES IN, 53.1 MPH W/ 40/52-3- STRUT NEUTRAL , 5S LIPO CONFIGURATION 1 2S AND ONE 3S PACK ON TOP OF EACH OTHER PERPENDICULAR TO THE MOTOR ALL THE WAY BACK. :thumbup:
6S HYDRO
Saw style runs guys, i know i know
Brushless55
08-15-2009, 08:27 PM
For some reason I cannot get my UL-1 to run 5s..
It goes into some studder mode! :doh:
longballlumber
08-15-2009, 10:00 PM
I hope you guys are not trying to run the stock UL-1 controller on 5S?!?!?!?!?!?!? I don't think that is what it was designed for...
6S HYDRO
08-15-2009, 10:12 PM
Exactly what the title says- stock ul-1. Have been running 5s on 3 of my sv's for over a year now. As long as your careful and watch your temps, you'll be fine
scoota
08-15-2009, 10:25 PM
what about the cut off voltage on the UL-1 esc its set for 12 volts , that will kill your 5s set up if your not careful . i only bring this up for the newbes thinking they can run 5s with no problems ...
Brushless55
08-15-2009, 10:31 PM
if one always runs your boat till the lvc kicks in, they could be taking their batteries down to far and hurting them..
runs should always be timed.. :cool2:
6S HYDRO
08-16-2009, 12:33 AM
I never run till cut off on 4s unless you want to puff the batts, and i would absolutely never run on 5s for more than a few laps.
Brushless55
08-16-2009, 12:55 AM
I agree bro! :banana:
that's a sure way to kill lipos.. :cursing:
6S HYDRO
08-16-2009, 12:59 AM
for some reason i cannot get my ul-1 to run 5s..
there's no way for the esc to detect over voltage. And those esc's are rated to 20 volts. Something's probably wrong w/ your 3s connector
Brushless55
08-16-2009, 01:14 AM
not sure?
I even put on a BEC and still it studders.. :confused2:
6S HYDRO
08-16-2009, 01:17 AM
Take off the bec- thats prob the problem. The stock ones handle it fine, like i said thery'r rated for 20 volts and ive been doin it on the 45a ones forever. Like i said before watch temps and short run times and you'll be fine
Brushless55
08-16-2009, 01:43 AM
the BEC is not the problem just added insurance... :thumbup1:
it did this before I put it on..
I'm thinking its my lame 12c batteries that's causing me issues..
when I run 4s I have some nice 30c packs that get me 50mph
Think I will put in an order for some good 3s packs this week, maybe zippies
Brushless55
09-05-2009, 07:13 PM
Ok I tried my new 2s and 3s 30c packs and dang!
I was running a S220 prop and this boat shot out of the water and was a handfull to get to top speed.. It kept lifting the left sponson up and out of the water.. Looked cool, nuts power!
after about two minutes my UL-1 took off all by itself? :cursing:
come to find out my external BEC was only rated to 3s! :w00t:
and when I put 4s to it and took off the bec, some smoke came from my rx! :doh:
NitroVal
09-05-2009, 07:37 PM
As far as Im concerned you are all liars unless we see some vids!!! :lol:
Brushless55
09-05-2009, 09:33 PM
Ya, that's a good one!
video of a smoking reciever :doh:
LiPo Power
09-07-2009, 09:45 PM
CC BEC up to 25V, 6S input with 4.8 - 9.0 volts selectable output using USB link
6S HYDRO
09-07-2009, 10:51 PM
i know my reciever started smoking today and i ran to get the camera, but by the time i got back it quit smoking so i didnt take any video
Brushless55
09-08-2009, 01:12 PM
were you trying to get a video of a smoking reciever?
:rofl:
6S HYDRO
09-08-2009, 01:27 PM
sarcasm
Brushless55
09-08-2009, 01:31 PM
:sold:
Rumdog
09-08-2009, 01:37 PM
How is an external bec rated at 3s? Why not just run a rx pack?
6S HYDRO
09-08-2009, 01:45 PM
you guys dont need any bec. stock bec in the esc works perfectly- even at 5s
Brushless55
09-08-2009, 07:26 PM
That's how is was made..
I though I bought a 6s BEC, but the burnt rx said not!
6S HYDRO
09-08-2009, 08:44 PM
if it burnt the rx that means the bec was putting out to much volts/amps to the receiver. like i said the esc's bec works great-no need for an external
Brushless55
09-08-2009, 10:16 PM
Yes yes yes...
I put on the BEC because of the issues that came with the first batch of escs I read about.. a little added insurance, so I thought :doh:
but I'm going to give my UL-1 a try on 5s and the stock esc :smile:
6S HYDRO
09-08-2009, 10:19 PM
just add caps to esc. every local radio shack has them for 1.39 ea. 35v 1000uf
Brushless55
09-08-2009, 10:28 PM
I've read about these. Tell me again what this does for the esc :beerchug:
and pics would help me out
6S HYDRO
09-08-2009, 10:52 PM
i add 2
6S HYDRO
09-08-2009, 10:54 PM
they are the weak link to the esc not the bec. you need to add on to the origional cap. i will try to get you piks of mine, but there are many on this forum
Brushless55
09-08-2009, 11:31 PM
Thanks!
mickvk
09-15-2009, 05:14 PM
I have trouble keeping mine down on the water at 36 (bone stock). I can't imagine 53. Nice work!
6S HYDRO
09-15-2009, 07:08 PM
somthing is wrong with your setup, or your in really bad waves, like on a full size lake or the ocean.
