View Full Version : mpi amp meter
seabassturd
07-23-2007, 08:41 PM
mpi mx8100 dc amp meter, 100 amp max 70 amp continous, 5-28v dc with deans on battery side, and alligator clips on motor side. and a astro flight model 102 6-7 cell discharger. package deal, both barely used, and work excellent. $25.00 plus shipping.
Stealth Assassin
07-24-2007, 10:07 PM
How does the amp meter work? what do the aligator clips hook to?
If It makes sense to me I will take It.;)
seabassturd
07-24-2007, 10:16 PM
you plug the battery in to the deans, then connect the alligators to the positive, and negative, on any dc motor (brushed) and it will tell you how many amps the motor draws, turn the switch to volts, and it tells you the voltage. it used to have deans on both sides, but i started hardwiring the escs in place, so the clips were the only way to go. i usually hook it up, go full throttle, and try and stall out the motor with a rag in my hand (wet) on my prop shaft, and see how many amps i could draw maximum. gotta be carefull however!! it may be sold to the gentleman that is taking the tranny. i'll let you know!
seabassturd
07-25-2007, 09:04 PM
sold, thanks very much!!
