View Full Version : Easy water outlet
topolino
07-19-2009, 08:33 PM
http://i484.photobucket.com/albums/rr208/dni1000/crackeroutlets002.jpg
http://i484.photobucket.com/albums/rr208/dni1000/crackeroutlets003.jpg
MT-Tank
07-27-2009, 09:05 PM
Love it! :thumbup1:
Have plenty of those on hand too.
Thanks for the idea.
Paul
6S HYDRO
07-28-2009, 02:41 PM
What is that? A little explanation would be great
topolino
07-28-2009, 02:58 PM
pop rivet? water outlet?
pop rivet is a very popular rivet..you can find in aluminum or stainless steel..
water outlet is out of the water cooling system of motor / esc or Bilge pump ... remove the inside of the rivet, just make a hole in the side of the hull above the water line and connect the hose in the rivet ..
in this chris craft i use for a bilge pump..
cheers!!
http://i532.photobucket.com/albums/ee321/topolino_album/Imagem216.jpg
JimClark
07-28-2009, 03:33 PM
Been using pop rivets for a number of years. I actually prefer the dome shaped Aluminum ones as you can sand them with 1500 grit and polish them to a Mirrorr finish
Jim
sailr
07-28-2009, 04:15 PM
great idea! And they come in different sizes too!
topolino
07-28-2009, 04:43 PM
Jim,
Excuse my ignorance, but what is a "dome shaped Aluminum " ?
from here comes the pop idea...
http://i484.photobucket.com/albums/rr208/dni1000/interiorziza005.jpg
cheers!!
JimClark
07-28-2009, 05:05 PM
I will take some pictures shortly
JimClark
07-28-2009, 05:54 PM
If you look at the picture you see that there is actually a dome and the rivit hear is thicker near the opening. Hope this helps
http://jimclark.smugmug.com/photos/604533715_83aRf-X3-1.jpg
topolino
07-28-2009, 06:23 PM
ow..its a kind rivet too...
thank you Jim!!
JimClark
07-28-2009, 06:48 PM
It is an aluminum pop rivet.
Jim
bigwaveohs
07-29-2009, 12:17 AM
cheers!!
I love the Chris Craft...is it scratch built or a kit (whose)?
yurkanip
07-29-2009, 10:54 AM
That is a fantastic idea.....going in two of my builds as we speak. Thanks again. This site is great for ideas like this....I really appreciate builders helping builders.
z400
08-04-2009, 12:08 AM
http://i21.photobucket.com/albums/b265/ride_wake_210/FE/IMG_0626.jpg
bigpapa
08-04-2009, 11:35 AM
sweet idea !!!!!!!!!
Jeff Wohlt
08-04-2009, 11:47 AM
I'm iwth Jim...been using them forever. I have also used them for antenna mounts to slide my tube in. I usually now take a nylon bolt and lathe the hole in the center then bolt thru the hull then run tube thru it.
I do use shoe-goo on both side to lock it in and seal it.
questtek
10-09-2009, 02:55 PM
Great idea...I am now using them for the exhaust cooling fitting on several boats. Antenna idea is also a good one, much easier and less weight that the current brass fittings I am using. Thanks.
LiPo Power
11-26-2009, 07:35 PM
Hi
How do I remove the pin out of my rivet please?
I was trying but it's sitting inside so tite I will damage it if more force applyed...
Robert
topolino
11-26-2009, 08:08 PM
Hello .. take a long rivet and cut the tip with a saw .. not just cut the tip of the pin .. cut a part of the body of the rivet is also
... then it is easy to get the pin with a pliers
pay attention in the first photo of this page where I have 2 rivets in my hand
LiPo Power
11-26-2009, 08:19 PM
Hello .. thank you. That was easy...
crabstick
11-26-2009, 09:44 PM
Hi
Robert
I just hold the flanged side and tap the pin through with a small hammer
LiPo Power
11-26-2009, 10:37 PM
I did just that, it works great, thank you. Great idea for water outlet.
Robert
