just bought some new nmh 5000mah packs from cheap batterypacks they have no charge info with the wanted to know what amps to set charger on
battery charge amps
trying to get used to this hi tec stuff just bought a hyperion charger its pretty neat just have to figure out the fancy charge rates . and what to charge packs at. im guessing if they say 5 amps max for the 5000mah packs . about 4.2 amps might not be to hard on them now have to figure out how to discharge packs without doing damageComment
Normally, when you set the mah on the charge it sets the appropriate amp rate.My prop hasn't been wet in a while.
