View Full Version : WTB: 200 amp+ speed control
hkusp45
07-17-2007, 01:12 PM
Im looking for a 200+ amp speed control.
Anybody got one??
Jeepers
07-17-2007, 07:32 PM
is that for your NEU motor that you just picked up?
hkusp45
07-17-2007, 09:08 PM
Yes sir it is!!
Ive been told that Ill need it!!
Jeepers
07-18-2007, 12:13 AM
I have heard that as well.
Rc1racing
07-19-2007, 10:36 PM
Hydra 240s are $30 off at http://www.towerhobbies.com use the promo on the home page.
254.99-30=224.99
Piranha2
07-21-2007, 10:38 PM
If you decide on the 240, be prepared to have your work cut out for you. There's 10-10awg wires to solder together.....real pain in the butt.
Rc1racing
07-21-2007, 11:13 PM
Your right it is kind of a bad design but mine works great as does all my other Castle Creations esc. They should of joined them at the board then ran a single wire out. Its just a little extra soldering. Its not that bad I had mine together and running my boat in an hour and a half.
Join the two wires together leaving about an inch or so on one of them. Then solder you connector on the end of the single one. Instead of trying to solder all three(the 2 wires and the connector) all at once.
hkusp45
07-22-2007, 03:36 AM
Good Diragram!
Thats what I was planning to do.....
Now if I only had the cash!
Gilbequick
07-22-2007, 10:32 AM
Wouldn't that defeat the purpose of the 2 wires? If you do that then you're putting alot more stress under the one wire that's going to the bullet connector.
I would think to be as efficient as possible the parallel wires would need to be the same lengths. Rc1 I'm not saying your setup doesn't work for you, but that just doesn't look like it's the best thing to do. It defeats the purpose of buying that beast of a controller!
hkusp45
07-22-2007, 01:39 PM
Could you show us how you are parrelling the wires?
Raydee
07-22-2007, 09:03 PM
Personally I am going to run 5.5mm bullets on each wire and then solder the positive bullets together and the negative bullets together. That will leave 4 bullets from which I will heat shrink over the extra bullets and just use the two I need.
Gilbequick
07-22-2007, 09:31 PM
I don't own one so if I did.....I would think to have the least amount of resistance you'd have to solder both wires directly to the motor lead.
Jeepers
07-22-2007, 11:49 PM
why not just solder one wire into the bullet connector, and solder the other wire to the outside of the same connector,(like this see pic) then cover with heat shrink, save you from using 2 connectors.
ReddyWatts
07-23-2007, 12:03 AM
A single 5.5 bullet connector with handle up to 200 amps.
hkusp45
07-23-2007, 03:56 AM
Looks like this is the best way yet.
On the power side. If you were running a 2P setup could you use one set for each batt? It should work but lookig for other opinions....
Raydee
07-23-2007, 06:42 AM
According to Castle you CANNOT wire them that way.
hkusp45
07-23-2007, 06:55 AM
Is that listed on there site?
Jeepers
07-26-2007, 12:26 AM
probably needs the big 6 mm then.
I dont ever plan to build any thing that needs to pull 240 amps.
wickedgmc
07-26-2007, 12:34 AM
no it does not, but it does say so in the manual or 5 sheets of paper you get....
