I can't seem to find 3M DP270 very easily here in Canada. Are there other products that I can use that will be easier to source?
waterproofing a receiver
You can get it here... http://www.offshoreelectrics.com/pro...prod=ose-dp270Government Moto:
"Why fix it? Blame someone else for breaking it." -
Thanks but it is about $20 to get Steve to ship something to Canada so that makes this some pretty expensive stuff.Grand River Marine Modellers, el Presidente
IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro TunnelsComment
I connect all wires etc then wrap it all with plastic electrical insulation tape,it makes it very waterproof and helps vibration a bit.
Spending a good 10 mins. or so makes a fine,neat job.Plus its easy to remove,if needed.
Brod..Slow gets boring fast.Comment
I'm with Rumdog.
A balloon costs 2 cents & takes 30 seconds. Why complicate things with anything else.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Traxxas make a nice waterproof receiver box for the 1/10 truck called the Slash. I have one in my truck, but I think it would work well in a boat. It retails around $12. RussComment
As I have said many times....CONDOMS works best. Also, a camping soap box also does a nice job.
Balloons have too small of neck. Condoms need to be used that are non- lubricated. Zip tie the end and you are done. You must remove them at the end of the day because of condensation.Comment
The only problem with using condoms or balloons with the FAST Futaba system is that they have a tendency to warm up while being used and if you "bag" them they will overheat and fail. RussComment
hmmm...I have had a few almost smoking and they never gave up! :)Comment
