View Full Version : finish modding my boat or get a new one?
koshokid
07-06-2009, 07:09 PM
I'm currently at the point where I've replaced the motor, ESC and batteries in my Apache so it's plenty fast but I'll need to drop another $100 on a new flex shaft, strut and rudder system. My question to you fine people is do I spend the $100 on the new parts, then spend the time and money to gut the boat and fiberglass the inside and hope for the best or should I just get another boat altogether? The other boat would be this one - http://www.novahobby.com/brushless-mini-deep-racing-boat-p-97.html
There is a certain appeal to the deep v as I hear it's self-righting if taped up properly. What do you guys think?
I'd more than likely convert my apache into a rescue boat if I got the other boat.
illz302
10-21-2009, 02:41 PM
Why not look at this one as an option too
http://www.minicatracingusa.com/vmono.html
or this one
http://www.minicatracingusa.com/vcat.html
the cat will handle rough water better and the mono will only self right its self if the weight balance is correct.
SweetZ28
10-21-2009, 03:49 PM
I am having problems getting mine to go fast with a 3300KV motor i only got 18.6MPH!!
If you don't mind what you using in yours?
Mine seem to run wet no matter how i angle the rear prop strut?
THANKS
Jesse J
10-21-2009, 03:55 PM
get/build another one. I have read lots of complaints about how the apache handles. This is the exact reason I built mine out of balsa/ply - at the same dimensions. Here is a couple vids of how she handles:
2S: http://www.youtube.com/watch?v=Rb6j8VSgYsY
and for kicks I tried 3S: http://www.youtube.com/watch?v=FS1xrUMXo-o
I have the plans I used and can help describe the set up better if anyone wants. Could even use whatever components you have in your apache now (except the steerable outdrive)
koshokid
11-17-2009, 10:51 PM
OK, I decided to keep the stock drivetrain setup and cut the insides out to accomidate 2 - 2s 5000mha, wired them in parallel to a 35 amp ESC powering a 3,549 RPM brushless motor. Here's a crappy vid from my cell phone.
http://www.youtube.com/watch?v=eTtfRWlgdaY
SweetZ28
11-18-2009, 11:20 AM
Nice!
Mine flys now on 3s with the 3300KV motor and it handels really good also.
koshokid
11-21-2009, 07:41 AM
Jessie, that's a sweet looking boat you built there. The main problem with the Apaches not being stable is that the battery placement is too high, making it flip easy. Mine hasn't flipped since I've been using the double battery setup.
illz302
02-03-2010, 05:13 PM
can you guys post some pics of the inside setup of your apaches?
