View Full Version : More Prop Testing
Drag Boat Bob
07-03-2009, 12:28 PM
Here are the new props that I have tested the last couple of days on my stock UL-1.
X640 - GPS: 49.3 mph. Good prop, but I prefer the Grim 38x63 (GPS: 50.2 mph)
L40x57(3): First run GPS 23.7 mph...lol. I didn't get the collet tight enough...duh.
L40x57(3): Second run GPS 50.2. Way too much cavitation. I will need to do much more sharpening (I hate sharpening 3 blades...)
L42x66: First run GPS: 50.4 mph and the boat was getting out of shape. The light wind was enough to make me let up on it or risk blowover.
L42x66: Second run GPS: 52.3 mph and the ride improved a lot by putting the batteries cross wise and all the way to the front. This run was real short due to the number of geese in the way. They are not afraid of anything.
I did add 2 additional caps to the ESC for safety before running the last two props.
I will get a few more runs on the L42x66 and the L40x57 (when I sharpen it) and then on to the m445...
detox
07-03-2009, 05:13 PM
Great info...thanks!
I have also found out if you add more weight (lead weight) to the left hand side of UL-1 hull it will not chine walk as bad. This counter weights the rotation lift of prop spinning.
Drag Boat Bob
07-03-2009, 06:32 PM
Would that be inside the tub or somewhere on the outside of the hull?
Also, how much weight are we talking about?
Brushless55
07-03-2009, 06:33 PM
Great stuff!
what is your fav prop, and why?
Drag Boat Bob
07-03-2009, 06:51 PM
Great stuff!
Well, the jury is still out on most of the later props, but of these three (38x55; 38x63; x640) I prefer the 38x63. I am an inexperienced driver and when I make too sharp of a turn and shed some speed the 38x63 accelerates well. Good hook up.
I was very surprised to see the amount of cavitation with the L40x57/3. It took too long to hook up. I am assuming that this is due to my lousy sharpening job. Time will tell... :confused1:
detox
07-03-2009, 07:17 PM
You can use peel and stick lead weights taped to outer left hand sponson. I believe Brain Buaas used ONE 4S LIPO BATTERY mounted inside lefthand side battery compartment when he recorded his 60 plus mph run using stock UL-1.
Brushless55
07-03-2009, 07:37 PM
is this the one?
http://www.offshoreelectrics.com/proddetail.php?prod=dh-aqub9758
thanks
07-03-2009, 08:10 PM
I was very surprised to see the amount of cavitation with the L40x57/3. It took too long to hook up. I am assuming that this is due to my lousy sharpening job....
Not surprising at all. Most lifting props will cavitate some to a lot before hooking up - and some never do hook up from a dead stop. The reason is due to the lifter's wider thrust cone - lifting props push some water downwards rather than straight back, reducing thrust and causing aeration. Non-lifting props generate their thrust back to push the boat forward. But lifting props can be good, particularly on hydros. You just have to use what works with your setup, cells, etc.
Drag Boat Bob
07-03-2009, 10:37 PM
is this the one?
thanks
Yep, dat b da one...
For me. a much better prop than the Grim L38x55. Acceleration was much better and I had absolutely no temp problems. Better top end also.
However, the L42x66 showed real promise the first time out. Too windy to try again until tomorrow... I will post results.
Drag Boat Bob
07-03-2009, 10:48 PM
but.. but.. but..
with the exception of one, all of the props I tried (5) were lifter props.
However, this (L40x57) was the first 3 blade lifter and being an old boat drag racer , they will cavitate more than a 2 blade simply because the blades are closer together. Each blade needs to move beyond the previous blades "cavitation" for better bite when high rpm is involved. At least that has been my experience.
Brushless55
07-04-2009, 01:06 AM
Thanks Drag!
I may try that prop on my UL-1
07-04-2009, 01:44 AM
but.. but.. but...
Like I said, most lifters will cavitate some to a lot - you saw both extremes with the props you tested. But in fact the "L" Grimracer props do not have the degree of lift of more traditional lifting props like the Octura 1400 and 1700 designs. They do have more lift than "X" and "M" series props though.
For R/C drag racing, lifting props are not the ticket. When our club members were experimenting with drag racing, we found the "X" series props gave the best hole shot. Here the x-tongue was an advantage in 'grabbing' the water faster - top speed isn't an issue. The fastest accelerating rigger in the club used a 3-bladed "X" prop - nearly 80 mph in less than 200 feet. Full-scale experience does not always translate directly to models........
Drag Boat Bob
07-04-2009, 08:46 PM
OK, I bow to experience... :bowdown:
I will give the 3 blade it's due.. thanks...
ronn25
07-07-2009, 10:04 PM
Drag Boat Bob those are great speeds. How is your stut setup, depth and angle? Stock turn fin? Are there any other mods?
I'm going to try a 38x63
I would be happy with 46-50mph so far I've only got 44mph with M445 prop.
Drag Boat Bob
07-08-2009, 11:15 AM
My boat is completely stock except for the addition of 2 caps to the ESC (mainly for safety reasons). I did add epoxy through the turn fin holes (with syringe) before the boat got wet.
I am using the stock water jacket, but moved the water exit tube to one of the available fittings on the top. This dropped my motor temp by 10 to 15 degrees.
The strut setting when purchased was about 7/8". I have dropped that to 1" with no other changes to angle etc.
When I finish with prop testing (I have not tested the m445 as yet) I plan to change the collet to a Kintec model and add the bearing.
I have not touched the hull, but plan on it after prop testing.
detox
07-08-2009, 09:02 PM
I've said it before, but adding weight to lefthand side of hull will help UL-1 handle better (less chine walk). The steep 4 degree AOA helps hull be loose and fast down the straits. The excellent turn fin keeps boat planted in turns if adjusted correctly.
ronn25
07-08-2009, 10:23 PM
I will try this...seems I have to put a lot of negative angle on the strut to keep it from blowing over, but it slows the speed down. I had to add about 6 oz to my miss vegas because it would blow over above 45mph
Capt. Crash
07-09-2009, 11:50 AM
By left do you mean port side? :confused2:
detox
07-09-2009, 02:42 PM
Correct...lefthand side of boat as if sitting in boat and facing forward. Opposite side to turnfin side.
Capt. Crash
07-09-2009, 02:57 PM
Hmmmm....I have more weight in the starboard side due to all the added glass of the turn fin/sponson repairs....I wonder if that makes my boat more prone to wobble?
I would think more weight in the turn fin sponson would help it plant better in the corners...but what do I know...it's my first hydro :bowdown:
What's the reason more weight in the port side sponson is better...counter acting prop torque?
detox
07-09-2009, 03:46 PM
Correct.
The starboard side is held down with turn fin if adjusted properly...read manual.
Drag Boat Bob
07-09-2009, 08:04 PM
It used to be that we ran left hand props because the driver sat on the left/port side (sorry, drag racing days again). This weight helped compensate for the counter-rotation "lift" of the prop torque and helped balance things out.
With added weight on the right/starboard side, it would be like adding to the counter-rotation lift, and could very well ADD to the torque roll and subsequent bounce.
I agree with Detox. Adding weight to the left/port side is the most logical when running left hand props. Also the bigger the prop, the more counter-rotation torque.
Currently, in the big boat world, this was cured by running twin counter-rotating props in TFH.
In my prop testing, I am finding that as I increase the prop size, the lift on the left/port side is greater. Only in absolute glass water is this not too much of a problem. With a slight chop things start to get hopping...
Then of course, I am still new at these rc boats...
Drag Boat Bob
07-14-2009, 11:25 AM
Well, I have finished prop testing for now and here is what happened:
L40x57/3 - (GPS= 50.9 mph) I spent 2 hours re-sharpening and I think I got carried away since it looked a bit smaller when I was finished. It was so sharp you could shave with it. No more cavitation problems to speak of as long as you keep the speed up. This is a good prop.
m445 - (GPS= 51.1 mph) This is a wild ride. I could not keep it under control in the corners. It was out of control with ANY cross wind. Exciting, but probably too much for my setup. I do not understand why this prop was much wilder (and a bit slower) than the L42x66.
Bottom line with the props tested: I prefer the L38x63 as the best all around prop. Good speed and great acceleration.
Interesting finding: The more I tested the larger props the slower the boat went. The motor leads were up to 151 degrees (I may have a problem here). I think I will have to change to the bullet plugs. :confused1:
I also have been testing flex cable lubricants (even mayonnaise) and have a lot more to do on this subject, but I can say that there is 3 to 4 mph difference here (another post). :tongue_smilie:
Brushless55
07-14-2009, 12:11 PM
Start the thread! :banana:
longballlumber
07-14-2009, 12:17 PM
Bob,
Can you give us the rest of your set up:
Strut depth and angle
battery set up (mah, how many P)
Turn fin +/- angle
Thanks
Mike
Drag Boat Bob
07-14-2009, 04:12 PM
Bob,
Turn fin +/- angle
Thanks
Mike
I think I have given this sometime back, but here goes.
Strut: 1" (dropped from the stock 7/8")
Strut Angle: Approx 1-2 degree negative angle. This is the way it came.
Batteries: (2) Max Amps 6500 mAH, 2S in series.
Turn fin: stock lower setting. I tried it raised to the next hole, but couldn't corner well.
Rudder: Removed lower bolt and used a Kintec nylon (thinner) shear bolt. This allowed for a few degrees of positive angle.
longballlumber
07-14-2009, 04:25 PM
Thanks for your reply!!!!
Drag Boat Bob
07-14-2009, 04:32 PM
I won't be able to continue the testing for 3-4 weeks, but this should give me time to change the motor connectors to larger ones. Their increased temperature was not indicative of the other components.
detox
07-23-2009, 04:45 PM
Octura x442 works verywell !
Drag Boat Bob
07-23-2009, 05:41 PM
Aren't you running that NUclear power plant though? :tt2:
Don't forget I'm running the stock spinner.
detox
07-23-2009, 07:37 PM
I am currently using the stock UL-1 system.
I burnt up the Hydra 120 using the 1515 1y and m445 prop, but boat was a missle on water while it lasted. I had several runs using the smaller m440 without failure, but esc temps were around 175 degrees (too hot).
Drag Boat Bob
07-23-2009, 07:51 PM
Sorry to hear about the meltdown.
What is the performance like with the stock UL-1 setup and the m440?
detox
07-23-2009, 07:55 PM
Gps reading of 49.9mph in not so perfect water.
