View Full Version : cant full throttle my UL-1
troettele81
07-02-2009, 04:23 PM
So Ive ran my UL-1 maybe 5 times. But all of a sudden its doing something weird. Basically, I cant full throttle it. When I do, the boat just quits. Then about 10 seconds later, it beeps, and its fine again. I can run it at about 3/4 of the throttle, but if I go any higher, boat quits. Driving this thing isnt nearly as fun as full throttle. Everything is stock, except for a Kintec water jacket, but I know that has nothing to do with it. Anyone else have this problem or know whats causing it?
bigpapa
07-02-2009, 04:46 PM
probaly a bad connection at motor or esc check all connections if all good it's the esc
good luck
teach
07-02-2009, 06:47 PM
Low voltage cut off maybe?
Brushless55
07-02-2009, 08:34 PM
what batteries are you using?
troettele81
07-02-2009, 09:58 PM
Two Thunder Power 2-cell 3200MAH Lipos.
FoxProGT
07-03-2009, 01:43 AM
sounds like the bad capacitor issue ...... check the top of your cap and if its swollen or even just a tad bit rounded then it has popped and will need to be replaced... i just had the same issue with my ul-1 and it was indeed a bad cap as other here have said. :(
or you could send it back in to get it replaced as long as is still within the warranty limit and you got the receipt :/
troettele81
07-03-2009, 03:05 PM
The capaciter has a bump on the top, so I take it thats the problem? I dont have a warranty anymore. I just ordered a 10 pack of the rubycons from kintec racing. I just pull the old one off and solder on a new one?
FoxProGT
07-04-2009, 11:06 AM
yeah pull the old one off but solder the new one directly to the power wires. that should fix your problem. :)
