View Full Version : My Blackjack 26 Build
Christaphason
06-25-2009, 09:26 PM
I recently signed up to OSE but been viewing for months so, I Just thought i would share my blackjack with everyone.
As of right now I am running the stock motor with an Etti 150amp esc.
Fuller's Hardware.
2.4ghz Futaba Fasst
I have a couple questions I drilled a new hole to angle my turn fins, how does this compare to completely taking them off. I do not race the boat, its mainly just for playing around.
One more thing, I ran Octura x642 and got 35.6mph with 7 cell nimh, but have any of you guys tried Prather 220.
Also i just got my 7.4 volt lipo's in that ill be running with bullet connectors so hopefully i can pull more speed out of her :laugh:
sorry about the picture i had to resize in MS paint......
if your looking for speed I would go with a lipo and a 5s and it will scream I was able to modify my stock turn fins to work and it works also if ur esc can take it use 6s and get a ammo 2300. I hit 47.3 stock apart from a grimracer 40-53 and a 5s
motohead417
06-26-2009, 12:31 AM
Hey sick hatch cover. Where did you get it?
Christaphason
06-28-2009, 08:49 PM
I got the hatch from Kintcracing.com
Today i ran my BJ26 on my 7.4v 25c 5000mah lipos.
My fastest run way 38.5 mph.
Should i be running faster with my setup or is it time step up to a new motor
Im running an Etti 150 amp
I also Angled my turn fins in.
5.5mm Bullet connectors on everything
Fullers Hardware
2s 5000mah 25c lipos
Octura x642 and Prather 220
My best run was using the Prather 220 prop
domwilson
06-28-2009, 09:36 PM
Do you have pics of the setup? Like the business end and the battery placement?
Christaphason
06-28-2009, 09:41 PM
Ahh i do not at the moment but i will get some next time i run
I had my batteries about 3 inches from the transom.
I played with Strut angle a bit and was able to pull out that .5mph
Maybe it will just need more fine tuning
Ill try to get pics sometime this coming week
domwilson
06-28-2009, 09:43 PM
How is the strut height?
Christaphason
06-28-2009, 09:46 PM
The last time i tweaked it, i had it pretty mush even with the angle of the stuffing tube. This is actually pretty straight with almost no angle at all.
domwilson
06-28-2009, 09:49 PM
Try adjusting the strut height, not angle, up in 1/8" increments. See if that helps with the speed.
Christaphason
06-28-2009, 09:56 PM
Thanks ill try that out this week, and ill let you know how it works out.
domwilson
06-28-2009, 11:10 PM
You'd be surprised at the difference a little strut adjustment can do. One of my cats went from high 20's to a low 40's just by playing with the adjustments.
Christaphason
06-28-2009, 11:23 PM
Yeah i was starting to adjust today, but rain prevailed and i decided to pack up
animigan
07-06-2009, 10:00 PM
Just to clarify, that hatch comes from kintECracing...
http://kintecracing.com/Black_Jack_26.html
Christaphason
07-11-2009, 04:40 PM
So i got a Feigao 8xl installed on my BJ26. The boat was significantly faster and had a lot more power.
Well i thought id test this power out and made a fast pass by, and long story short this boat doesn't like doing 10 flips at over 40mph
So im thinking about pulling all the wood out of the boat and making new rails out of carbon fiber.
domwilson
07-11-2009, 04:43 PM
Harsh...Looks like the epoxy let loose.
Christaphason
07-11-2009, 04:51 PM
Yeah that's what happened, the epoxy the factory put on it was done very poorly, i'm actually surprised this didn't happen sooner. Although i hadn't had a crash as harsh as the one today.
Im gonna fix her up though!
domwilson
07-11-2009, 05:35 PM
Epoxy... Just a few minutes ago, I was moving the wires on my motor in another boat, after reading this. And guess what? The epoxy on the motor mount gave way. I guess your bad luck has spread...:just-kidding: Gonna use 2 ton for this.
